Hammer Options
ALW
#1 Posted : 06 November 2015 11:50:48
Hello all
Can someone recommend a small hammer for the pins that fasten the
aluminium panels?
Thanks
#2 Posted : 06 November 2015 12:12:06
Hi Alan,
Any of these should do the job nicely. I also use small long nosed pliers to hold the pins in place, find it easier than using a pin pusher...
http://www.cornwallmodel...ammers_pin_pushers.html
Hope this helps.
ALW
#3 Posted : 06 November 2015 12:15:18
Hello Alan
Thanks, that's a great help.
Have a good weekend!
#4 Posted : 06 November 2015 12:28:53
Its a good idea to pre-drill the pin holes slightly smaller than the pin diameter, so that when the pins are tapped in, they are a snug fit and its not such a shock to the airframe and less chance of splitting the wooden formers we the pins are tapped in.
Be very careful if using a pin pusher, it can put undue stress on the airframe and also indent the skin surrounding the pin.
ALW
#5 Posted : 06 November 2015 14:07:24
Hi Tomick
Thank you for your advice, points noted.
Regards.
