Perma-Grit Sanding Blocks Options
#1 Posted : 05 November 2015 22:11:00
BigGrin Hi ALL
These arrived today there the wedge and flat 280 mm sanding blocks each has a coarse and fine face on each side of the sanding block. The price can put people off these tools but when I say I expect to get 20 years use from these there cheap as chips and if you add up 20 years worth of sandpaper prices I still think these would be cheaper.
http://www.permagrit.com/index.php?cPath=65
#2 Posted : 05 November 2015 23:14:17
BigGrin I have got a couple of these and they are brilliant well worth the money Cool
Reg Martyn
greyhawk
#3 Posted : 06 November 2015 02:05:26
#4 Posted : 06 November 2015 19:42:33
BigGrin Hi Greyhawk
These sanding tools are made of tungsten grit welded to the surface of the tool. When they say rough it will take a serious amount of wood or metal off whatever your sanding very quickly the fine is a lot more gentle but works consistently.
As for 'P' numbers why dont you contact Perma Grit and ask them as there more qualified than I to answer that question. Hope this helps.
Silent_Running
#5 Posted: : 07 November 2015 02:45:00
Reg Martyn
I've got some too Martyn, and you're right well worth the money. If you want to sand a flat surface just place the block on the table and whatever your sanding ends up perfectly level. I use mine all the time. Fantastic value for money and top quality! BigGrin
#6 Posted : 07 November 2015 22:57:22
BigGrin Have to agree with all your comments once you start using these tools you wonder how you managed without themCool
This page was generated in 0.130 seconds.
