 Rank: Pro  Groups: Registered
Joined: 18/03/2010 Posts: 121 Points: 359 Location: Waterlooville, Portsmouth. The home of HMS Victory.
Following instructions carefully I inserted the pins at an angle at the plank ends to prevent splitting. Alas they still split. A bit of help on this one would be very much appreciated.
Paul
Joined: 17/03/2010 Posts: 147 Points: 448 Location: dingwall,highlands of scotland
When dry fitting the plank ,mark the position where the pin will go and drill a small pilot hole at an angle. CURRENT BUILDS HMS HALIFAX HMS BOUNTY LYDIA EVA(STEAM DRIFTER) MANTUA COASTAL CANON COREL VICTORY CROSS SECTION TAMIYA 1/35 MATILDA MK 2 HACHETTE TIGER TANK DRAGON 1/35 TIGER TANK
Very much appreciated, thank you.
Joined: 30/03/2010 Posts: 126 Points: 335 Location: Bradford West Yorks
came up with the same answer as cliff but he beat me to it
