Differential fit Options
ncall1976
#1 Posted : 29 October 2015 16:55:04
Has anyone found that one bearing isn't as tight as the other on the diff case?
Slight wobble to it
#2 Posted : 29 October 2015 17:16:16
The bearings are not a very tight fit on either the diff itself or the inside of each eccentric. The fit is very slightly loose but certainly not a wobble, so are probably best left off the diff until it's fitted into place.
ncall1976
#3 Posted : 29 October 2015 17:38:21
test fitted it to see if it was ok, still too much movement of the diff itself
supposed to be smooth circulation of diff
won't work efficiently if the diff is rotating incorrectly
ncall1976
#4 Posted : 29 October 2015 17:54:38
out of the other 17 cars I have, all are fitted with ball raced bearings and they have a tight fit on the inner and outer diameter to the relivent parts attached to, but the working part moves freely.
#5 Posted : 29 October 2015 18:18:21
ncall1976
#6 Posted : 29 October 2015 21:18:15
It's not the bearing that wobbles. It's screw end of the diff that's slightly smaller, as I have tried the bearing on both ends.
But I will contact cs to state an issue with it.
Thank you
