Joined: 14/04/2015 Posts: 238 Points: 716 Location: Newcastle
You could also only part plank the Perspex deck so you could see through the deck into the hanger.
 Hi Nem and Micheal Thanks both of you for looking in and your comments, Micheal the perspex is a black colour so not see through but its a good idea. Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All More progress the hull, all ladders have now been fitted along with the odd piece of furniture then all the railings were fitted. The main flight deck has been glued in place at the bow and the perspex deck has been cut out with my lecky fretsaw. In the pics the cut out deck has not been glued as yet along with the stern deck as some adjustments will be needed here and also some boats and furniture needs to be added here. More soon. Regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
wow look`s mint  i think i might go down the perspex route andy. COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
 Hi tigerace Thanks for looking in and your comments, Just having the flat top on makes all the difference I think. Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
She's some size of a build... looks fab Andy.... Regards Alan
She's an amazing looking carrier and looks like you've done a pretty amazing job on her too
 Thanks for looking in both of you and your comments Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All A little more done the central deck has had the underneath roughed up, primed and painted underneath and along the edges where it will be visible. I have left the upper protective cover in place as its a guide to replace the various refuges and girder work removed from the four original deck pieces. Next job is to replace these pieces and then the final fitting of the stern deck so the planking can go on. More soon. Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Loving your build Andy, definitely one to live up to. Graeme
Nice progress andy. Loving this build. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Another great update Andy, usual top notch work I see..... Regards Alan
 Stunning work as always Andy Reg Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Joined: 02/09/2015 Posts: 12 Points: 36 Location: Folkestone
Looking good. I'm taking notes as I made a start on my Akagi but found to have a few bits missing, waiting on admin to replace them
 Thanks for looking in and your comments everyone, there all very much appreciated Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All Just a quick update, the four prop shafts have now been added to the hull. More soon Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
nice work andy  the plastic card round the propshaft ends are your enhancement ? cheer`s phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Sterling work there Andy. beautiful work Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
 Hi Tigerace Yes the plasticard inserts are enhancements that represent the rivet flanges that surround these parts on real ships, I have also some faired brass section that was used on the Yamato build but it just a little too big for this build so stuck with the supplied ali bar. Thanks for looking in and your comments. Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi Hans Thanks for looking in and your comments. Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Guest (11)
