8 Pages 123>»
Martyns San Felipe build Options
#1 Posted : 17 October 2015 16:43:34
BigGrin Hi all hoping to start this build in the next few weeks. I have lots of ideas running around in my head of doing a bit of a custom job on this stunning ship still not sure what yet but it will be a all wood finish so that will push my planking skills Laugh
See you soon Rgd Martyn
kpnuts
#2 Posted : 17 October 2015 16:55:28
Look forward to seeing it.
#3 Posted : 17 October 2015 20:27:03
#4 Posted : 17 October 2015 23:37:21
Will be watching your build as you progress.
Trev.
#5 Posted : 17 October 2015 23:52:17
BigGrin Nice one, will be watching your buildCool
#6 Posted : 18 October 2015 00:36:23
Hi Martyn, this is a ship I really like the look of, think she is a beautiful looking kit and I for one will be an avid follower of your build.... Look forward to seeing you get her under way......Drool Drool
#7 Posted : 21 October 2015 15:01:01
BigGrin Thanks all for the looking in Cool
BigGrin Got some parts today in the post so had a look. Very nice packing and the parts are clean with no warping . also in the pack is some glue and sandpaper Cool
First job sanding and dry fitting the first rib to the keel . I found it to be a nice sliding fit into the slots BigGrin Next up glueing the rib to the keel . A small drop of PVA was appled to the slots and slid into place then with a setsquare to set the rib 90deg to the keel and set aside to dry BigGrin
Thanks for looking next update soon rgd Martyn
#8 Posted : 21 October 2015 19:58:03
Great to see you up and running Martyn, will certainly be looking in on this one..... Good luck with the build....Cool Cool
#9 Posted : 21 October 2015 20:47:55
Hi looks a very nice kit.will be following with interest. Cheers mick.BigGrin BigGrin
#10 Posted : 21 October 2015 21:30:00
BigGrin A very nice start MartynCool
#11 Posted : 21 October 2015 21:58:14
Good to see another Felipe underway Cool
#12 Posted : 22 October 2015 07:47:28
Great start Martyn. Look forward to seeing her grow.
#13 Posted : 22 October 2015 10:49:26
BigGrin Thanks for the comments Alan Mick Andy MR T and Chris Cool
I have started planking the deck and will post some pics later Cool
Thanks for looking in rgd Martyn
#14 Posted : 23 October 2015 15:22:47
BigGrin Hi all Cool
I have finished planking the deck and have moved on to the anchors Cool
The anchors are cast and with very little mold lines . The stock is also cast as I want a all wood finish I have made some out of walnut with tin foil bands to look like iron Cool
Next step is putting more frames onto the keel . As before thay have been set to right angles to the keel Cool As you can see I am useing a build jig to hold the keel in place BigGrin
More to follow see you soon rgd Martyn
nightwisher
#15 Posted : 23 October 2015 20:45:29
Hi martyn, good to see you back with another long term project,I thoroughly enjoyed your sovereign build from start to finish.Will be following your build log when I can inbetween work and trying to finish my sovereign.
Had a dream to understand
A single grain of sand
He gave birth to poetry
But one day will cease to be
#16 Posted : 23 October 2015 20:57:02
#17 Posted : 24 October 2015 00:30:06
Nicely done Martyn and I agree with you about the anchor, much better with wooden stocks.... Look forward to your next update...
#18 Posted : 26 October 2015 14:31:14
BigGrin Thanks for the bril comments guys Cool
Onwards with the build . I have fitted some more ribs to the keel and after they had dryed started fitting the lower decks Cool . I like the decks going in as it stiffens up the ship no end ThumpUp
Next job planking the top decks . The planks have been corked by useing a pencil along the edge Cool . After the openings have been cut out I could see the deck underneath so painted it black Cool
The bulkhead that comes through the deck I have planked with some leftover planks from the SoTs BigGrin
Thanks for looking rgd Martyn
#19 Posted : 26 October 2015 18:22:28
Neat work and coming together fast Cool
#20 Posted : 26 October 2015 19:10:40
BigGrin Thanks for the nice comment MR T this ship is a dream to build very little adjustments to the parts and I would recommend it to first time builder and the experienced Cool . It will slow down a lot when I get to the planking though Cool
8 Pages 123>»
