Alemo's D51 Build Options
alemo
#1 Posted : 13 October 2015 16:59:16
Hi everyone, I started this in the discussion forum before I woke up to where it should be, it takes a while to catch on sometimes.
So here's my build up to stage 21. I decided to paint the model and therefor I am painting components as I proceed.
Alec
alemo attached the following image(s):
Adapt, improvise, overcome.
alemo
#2 Posted : 15 October 2015 17:58:25
A little more progress, leaf springs and equalisers fitted.
One pair of wheels painted, three pairs in primer.
One small problem, I dropped an equaliser bush on the floor and found it eventually three feet from where it fell. I have lots of spare screws but no spare bushes, I haven't dropped a screw yet!
Alec
#3 Posted : 15 October 2015 18:03:28
Looking very nice Alec Cool
Gr33n1e
#4 Posted : 16 October 2015 10:52:59
Looking good, what paint are you using?
alemo
#5 Posted : 16 October 2015 11:18:08
Hi Gr33n1e,
Paint is acrylic Railmatch 2412 weathered black which was recommended by arpurchase. It goes on better with an airbrush but if not available get good quality brushes and use a primer either way. Degreasing is essential on all parts before painting. Hope this helps.
Alec
alemo
#6 Posted : 16 October 2015 13:05:44
Looking at fitting the wheels and I find that the axles are 10mm dia and the axle blocks have an aperture of 10.5mm dia. When put together it seems a very sloppy fit which may be required for the drive motor to power all eight wheels but seems a bit excessive. Has anyone else found this and is it right?
Alec
alemo
#7 Posted : 18 October 2015 13:06:24
Here is the latest to my build, drive wheels and connecting rods all fitted, wheels still feel a bit sloppy in the axle boxes, maybe when sitting on the rollers this will not matter.
All connecting rods fitted nicely, one not so good thread that would not start the screw but easily rectified by running a spare screw in from the opposite direction.
Alec
#8 Posted : 18 October 2015 13:56:19
BigGrin Looking good Alec very neat Cool
#9 Posted : 18 October 2015 20:00:50
BigGrin Looks great and nice workCool
#10 Posted : 18 October 2015 23:52:55
Very nice Alec, certainly coming along a treat....Cool Cool
alemo
#11 Posted : 19 October 2015 17:02:54
Thanks for looking in and for the kind comments.
Alec
#12 Posted : 19 October 2015 20:27:37
Alec
yes that is correct.It is not a very tight fit, but once the connecting rods are set up and the motor installed it is a bit more solid.However, it is still loose.I don't think this train would do well actually running on a track.The stand has it running on bearings.
I thought the same thing when building, but it does run pretty well on the bearings.
You are doing a fine job building this kit Alec.
#13 Posted : 20 October 2015 09:31:51
Very clean build so far!
alemo
#14 Posted : 30 October 2015 11:22:50
This giant is growing. Here's an update. I found that the sand pipes wanted to go their own way instead of where I wanted them but I won in the end, other than that all went well so far.
Alec
#15 Posted : 30 October 2015 14:57:33
Superb paint job ThumpUp
#16 Posted : 30 October 2015 19:12:34
alemo
#17 Posted : 02 November 2015 18:09:23
Just a small update, the back head is finished and waiting for the cab. The gauges are from roymattblack and the pipes are 1mm gauge wire and will need trimming to fit the floor.
Alec
#18 Posted : 02 November 2015 19:29:08
Looking great Alec, very nice work indeed...Cool Cool
#19 Posted : 02 November 2015 23:42:33
BigGrin Very nice work AlexCool
#20 Posted : 02 November 2015 23:58:35
Awesome job painting all the little details, it looks very nice!, Cool
