Shape of ribs Options
kzugaj
#1 Posted : 19 September 2010 22:24:55
About rib 15 was before but my rib 18 and 25 are little bit to small. I need to build them up. Anybody have that problem with ribs?
Jack Sparrow
#2 Posted : 19 September 2010 22:30:38
All I do with smaller ribs is stick a strip of 1mm plank down the length of the rib, or 2 depending on how much to build it up, and then sand it back. It worked a treat on my Black Pearl build and I will be doing the same on the Victory. BigGrin BigGrin
willie
#3 Posted : 19 September 2010 22:58:41
if you read TOMICKS post he tell you how to do it with card if you dont have thin wood
Zeptrader
#4 Posted : 19 September 2010 23:41:41
To add to this, when you sand the hull (fair) there will be areas where its not sanded, you can spot these quit easy, these are the areas to build up as mentioned above.
Some frames need adding to, some need more taking away, fairing is worth taking time over, believe me you will notice any dip's and springy planks if not done well.
I've just marked mine to indicate what frames need attention with a black marker.
Paul
#5 Posted : 21 September 2010 09:27:16
Location: Waterlooville, Portsmouth. The home of HMS Victory.
Morning all, Here in this link are some detailed instructions on hull fairing. Hope it helps.
Fairing the Hull
This page was generated in 0.175 seconds.
