Vulcan national tour finalised flight plans Options
#1 Posted : 07 October 2015 19:49:29
Your chance to see XH558 around the country as she embarks on perhaps her most comprehensive tour.
Northern tour 10th October
Amongst the places being visited on this route:
Gainsborough, Brough, Menwith Hill, Leeming, Durham Tees Airport*, Newcastle Airport*, Eshott Airfield, Alnwick, East Fortune, Carlisle Airport, Bowness on Windermere, Warton, Chadderton, Manchester Airport*, Woodford, RAF Cosford, East Midlands Airport* and Derby.
*Passes at certain airports will be dependent on ATC clearances at the time of arrival.
Southern tour 11th October
RAF Waddington, Rutland Water, North Weald Airfield, Gravesend, Herne Bay, Manston, Dover, Ashford, Dunsfold, Farnborough, Middle Wallop, Old Sarum, Bristol Airport*, Filton, Cardiff Airport*, St. Athan, Staverton Glos Airport, RAF Brize Norton*, Wellesbourne, Bruntingthorpe and Newark.
The crews will try their very best to pass directly over each main location. There is no guarantee of exact route following can be given due to operational conditions.
At least two more flights are intended in late October - This weekend (Oct 10th & 11th) will not see XH558’s final landing!
#2 Posted : 10 October 2015 08:46:35
The tour routes are now finalised. Link's to the route guide for each day are noted below, which now include approximate times from take-off if you click on your point of interest. Take-off on both days is approx 13:00
Times are added in minutes realtive to the take-off which wil be confirmed on the 10th & 11th along each the route.
10th Oct Norther route
https://www.google.com/m...oGZd3-Qg5U.k9_QAWQWnmes
11th Oct Southern route
https://www.google.com/m...oGZd3-Qg5U.k3u8IUZTll6M
The flight will consist of flypasts, orbits and level or climbing departures; no displays should be expected.
Monitor XH558 on social media to see where XH558 is in relation to you.
IOS app tracker: https://itunes.apple.com.../xh558/id458309050?mt=8
Android tracker: https://play.google.com/...?id=com.msapsford.XH558
This page was generated in 0.085 seconds.
