Dragon's 'Black Label' 1/35th Conqueror Tank Options
richmal
#1 Posted : 09 October 2015 12:53:47
Rank: Amateur Level 1
Dragon's 'Black Label' kits have been criticized for being under engineered and overpriced. However if you want a model of the Conqueror MkII tank the two current options are either this one or a far more expensive resin kit. I found this model both affordable and giving an acceptable look of the vehicle.
I am happy with the end result. Comments in either the negative (I'm not easily offendedCool ) or positive are all welcome.
richmal attached the following image(s):
#2 Posted : 09 October 2015 12:58:11
richmal
#3 Posted : 09 October 2015 13:06:43
Thanks Steve
I'm not a fan of too much weathering since I can't quite get the hang of the subtle tones needed to get it to look right.
One thing I am aware of after 25 years serving on British Armour is that, apart from some of the really muddy training areas, most vehicles don't have time to rust (cleaned/repaired after every exercise and normally repainted at least twice a year) and if operating in a normal environment dust rather than mud tends to cover the vehicles.
#4 Posted : 09 October 2015 15:03:08
Another fantastic build richmal ThumpUp
This page was generated in 0.100 seconds.
