Aileron part 2 Options
max001
#1 Posted : 04 October 2015 00:58:43
Rank: Amateur level 2
Have altered the largest one to fit the plate supplied,have a gap of a mil either end, bit much I like about a paper thickness each end. max001]
#2 Posted : 04 October 2015 10:23:46
Reading your post Max, can you post a few pictures for us to look at, on my build I have small gaps at each end, you have to allow for some movement.
Trev.
#3 Posted : 04 October 2015 11:13:00
A gap of approx 1mm at each end is as per the design.
