Terrible RC Unit! (but great car) Options
AcE_w1zArD
#1 Posted : 01 October 2015 16:47:26
Hey all,
Well after what seems like forever I finally received pack 19 the other day and completed the H1 build BigGrin.
Ran about half a tank with the engine idling (turning down the idle screw as required as the idle speed slowly crept up as the engine got worn in). I went to do some 1/4 throttle passes out in the street and did a few, then suddenly as I had just started accelerating the car just wouldn't stop!
Looked at the transmitter and the LED's had turned off. Had to stop the car with my foot before it hit something more expensive! The only damage was the plastic bull bars on the front. Fixed that with some superglue!
A quick knock on the bottom and it turned on again ?!? Im using Duracell batteries so I know they're made to proper specs and were brand new. Just seems as though the batteries can seemingly work their way loose when inside the unit.
Secondly, I have installed a Schumacher micro failsafe into the car which saved me twice yesterday from weird signals in the area. When testing functionality on the bench the throttle servo would start twitching and then go into failsafe mode. Looks like their is some 27Mhz interference around me :(
Anyway, ive bought one of the KT-200 transmitters from eBay brand new, this is the same radio provided in the RB7 build and is 2.4Ghz with a built in failsafe so should be better then the 'old skool' 27Mhz rubbish!
When the car wasn't acting weird or running wild it was great, turning circle is good and the suspension has tons of travel! Certainly feels less delicate than the RB7, something I could actually use without being terrified it will break! I havnt tuned the engine yet (as I stopped after the runaway) but it does seem a lot slower than the RB7, I suspect its not as its the same engine, I havnt checked the gearing either, we shall see.
Just wanted to see if anyone else had a similar occurrence of either interference of dodgy radio/battery behavior.
#2 Posted : 01 October 2015 16:56:03
27Mhz radio's have always been susceptible to interference (depending on surrounding's), 27MHz is the most common band in use and a good idea to fit a failsafe, or even better, a move to 2.4Ghz will give peace of mind..
AcE_w1zArD
#3 Posted : 01 October 2015 21:46:37
Yeah pretty much as I thought. As I say, the KT200 transmitter and receiver that comes with the RB7 are great, so have ordered one of those.
Shame the hummer was supplied with a old style transmitter, but it can be forgiven Cool
alemo
#4 Posted : 02 October 2015 10:51:52
I had the same problem, changed to 2.4ghz and all was well.
May be slower than RB7 because of the geared hubs. Seems to go anywhere without faltering, nice model.
Alec
Adapt, improvise, overcome.
AcE_w1zArD
#5 Posted : 02 October 2015 23:00:12
Alec
Good thinking RE the geared hubs! I have checked the actual teeth and they're identical on both models so must be the hubs, forgot about those.
The model does seem hugely capable, am loving that I can do the run-in in my back garden and seem to have plenty of torque to.
I'm building my RB7 in "running" trim so it will have its lexan racing body etc on it, but it will be for display only, its already sat on my wall at 90% complete :D. I know its a shame to have such an expensive and lovely thing wall mounted, but it cost so much money!!! 100 issues over 25 packs at 32.00 is £800.00, and that doesn't count the further 4 packs that the extension issue covers Crying .
I have ordered a new KT-200 transmitter + receiver, but for now I have just stolen the one from the RB7 whilst the new one arrives. Should be able to complete the run-in stages tomorrow and get some use out of this thing before the weather turns really bad. I can just fit the new transmitter straight into the RB7 anyway :)
This page was generated in 0.097 seconds.
