amati plank bender..for those who own one Options
benny
#1 Posted : 18 September 2010 15:08:14
hi i av just located my plank bender after buying it 4 months ago..plugged it in and guess what..it doesnt work.. i have never used it but my question is,is it 3 prong or 2?the reason i ask is mine has 2 pins but there is also a hole for a 3rd, has mine fallen out or is it supposed to be like that..i am trying to find out whats wrong with it so eliminating the obvious..thanks
cheers benny
Jack Sparrow
#2 Posted : 18 September 2010 15:10:59
I have that one, its from Italy and comes with that plug!! A shaver adapter is all you need, my local hardware store had one for about 3 quid!!!BigGrin
benny
#3 Posted : 18 September 2010 15:19:30
hi so the third hole is supposed to be there? and i have plugged it into the shaver adapter..shame i still dont have the paperwork
cheers benny
Jack Sparrow
#4 Posted : 18 September 2010 16:04:04
It should look like this.........
Hope this helps!! Jack BigGrin BigGrin BigGrin
PDyner
#5 Posted : 18 September 2010 16:24:47
HI
If you bought this plank bender with european type plug, the hole is for the "earth" pin which is located in the socket. Some plugs have only a recess or they are flat if the device doesn't need to be "earthed". So I think all sort of travel adapters should work.
Prem Dyner
#6 Posted : 18 September 2010 16:51:53
Simply cut it off and fit a UK three pin
benny
#7 Posted : 18 September 2010 16:55:14
thanks all thats what i was eliminating its an internal fault
cheers benny
benny
#8 Posted : 18 September 2010 17:26:09
i cut off the plug and put a 3 pin on and now it works thanks
cheers benny
