51 Pages «<1112131415>»
DaDokta`s Build Options
#241 Posted : 07 September 2015 13:07:56
Hi walter.
Looking vcery nice. IanCool BigGrin
#242 Posted : 15 September 2015 10:17:55
Hi guys, thanks again for your comments!
I want to show you the next update with the now completed base of the gallery.
As i mentioned before i don`t follow the instructions regarding the Gallery - do a little scratch build instead.
I bent some wooden profiles to simulate the real thing:
As the next step i will give the lower hull a few coats of semi-gloss varnish to seal it.
And then - and i`m very excited about that - after about two years she will leave the "upside-down"-jig and be put in her upright position at last!
I will then work my way up at the gallery, which again will pose a lot of challenges - especially because of the different height of the windows at the side parts and the rear part of the gallery.
Thanks for looking in,
z8000783
#243 Posted : 15 September 2015 10:24:40
Groups: Unapproved
Beautiful. You must be very proud.
#244 Posted : 15 September 2015 10:54:46
BigGrin Lovely work on the gallery Walter very nice Cool
#245 Posted : 15 September 2015 11:57:04
Outstanding work Walter, she looks fantastic ThumpUp Cool
#246 Posted : 20 September 2015 23:55:21
Looking great Walter, credit to your skills....Drool Drool
Hans
#247 Posted : 21 September 2015 06:29:45
Brilliant work there Walter, your patience and hard work are paying off. Well done.
Rgds, Hans
Endeavour Cross section,D51
Completed: HMS Victory
#248 Posted : 23 September 2016 10:17:12
Hi guys!
It`s been a year - and after a move and after completing my McLaren and D-51 build i will now again continue my Victory.
As mentioned before, i try to build the gallery and transom as near to the original as possible with my skills.
Earlier in the build i decided to use the enhancement transom part but stay with the side-gallery parts as they came with the partwork (the reasons for that have been discussed in extenso :-) ).
As i used different wood profiles for the gallery-linings, the different heights of the windows caused a lot of problems and each step took much consideration and time. I had to settle down for some compromises, as you can see in the pics.
So let me show you, where i am at:
As much as the side-gallery windows are sitting in the right height (compared to the deck height) using the original parts, they still are too big in height themselves in my opinion (i hope my english is understandable). So i attached the next wood-profile a liitle bit lower to reduce the height and to be able to connect with the profile on the transom as properly as possible:
After each step multiple rounds of tydiing up and painting!
As i will show you in upcoming posts, i had (and will have) to adjust the photoedge parts of the pillars (?)as when using wood profiles instead of the photoedge only, these parts are much too big.
I tried to simulte the decorations on the inside of the bulwarks with some twisted wire - i`m afraid it didn`t quite turn out as perfect as i would have wanted to, but it still is a nice effect in my opinion:
As always thanks for looking in![/size]
#249 Posted : 23 September 2016 15:44:27
Looking great. Some very nice changes you've done, your efforts are paying off...Cool Cool Cool
#250 Posted : 23 September 2016 16:28:59
BigGrin Looking good Walter very nicely done Cool
#251 Posted : 23 September 2016 18:00:07
#252 Posted : 26 September 2016 10:37:33
Thanks guys!
Here`s my next update.
I added the first row of pillars - as mentioned before i had to adjust the height of the pillars to fit properly.
Also some of the decorations were added and the next wood profiles attached:
#253 Posted : 26 September 2016 12:25:37
Hi Walter,
Class work again very nice.
Trev.
#254 Posted : 27 September 2016 11:46:08
Added some decorations:
#255 Posted : 28 September 2016 08:21:18
Added further decorations (unfortunately the center decoration piece was broken when i opened the box) and moved on to the side-galleries:
#256 Posted : 28 September 2016 15:57:48
Looking good Walter ThumpUp
A bit of epoxy should sort the broken decoration out, it looks to be a clean break Cool
#257 Posted : 28 September 2016 21:19:24
Hi Walter,
That was a tricky part to assemble with the different sizes to match up,but it looks great.
Well done Walter
Regards Trev.
#258 Posted : 28 September 2016 21:34:41
Hi Walter
Your build is looking very nice.
Amazing just how many parts go to make up the stern of the ship but all looking very good indeed.
#259 Posted : 28 September 2016 22:50:59
Lovely work Walter, doing a great job with the gallery....Cool Cool Cool
#260 Posted : 29 September 2016 08:44:29
Guest (5)
