5 Pages «<2345>
Trumpeter T90 MBT 1/35 Options
#61 Posted : 20 September 2015 23:23:04
BigGrin Lovely job Dave looking good Cool
#62 Posted : 21 September 2015 00:16:48
Some great looking work on show Dave, coming along really nicely...
#63 Posted : 21 September 2015 18:04:31
Thanks Martyn and Alan.
Well today I had a go at putting the asks over the yellow to spray the green, the only problem was the masks didnt seem to match up with the yellow already laid down Cursing
So I took my 16 year old step daughters advice and went freehand "as it would look more natural"
So I dialled down the pressure and went gave it a shot, I'm quite impressed with the results. There is overspray in the yellow but after checking my reference photos I noticed that it also had quite a lot of overspray.
Im thinking that I should have done the black first so that the green softens the edges of that too, Although I dont think I will use the black the painting guide recommends as the reference pictures shows its more of a bluey black Confused perhaps Nato Black??. I will have to have a look what I have.
Comments good or bad welcome, its my first camouflage scheme so if it doesnt look right then I need to know BigGrin
Also any recommendations for filter colour greatly appreciated BigGrin
#64 Posted : 21 September 2015 21:14:27
BigGrin BigGrin Hi Dave nicely done and looking great as for Nato black its more of a green/grey black but I have found that this kit helps for shades of black. Whoever said black paint was just black LOL Love Drool Drool Flapper Flapper Flapper I know its for rubber effects on tyres but it can come in handy for other things too.
http://www.ebay.co.uk/it...717?hash=item58cb515785
#65 Posted : 21 September 2015 21:29:46
Thanks Andy, thats a few shades of black LOL
I think I am going to go with the Nato Black.
Here is the turret done, this was done completely freehand. I learned something new here after doing the green first, that the Mr Colour Yellow I used doesnt spray as well in a fine spray so once I have done the black I will go over the turret again with the green to tidy the edges.
The barrel still needs green adding too.
#66 Posted : 22 September 2015 08:41:33
That is looking superb!ThumpUp
#67 Posted : 22 September 2015 08:47:56
Thanks Nemesis BigGrin
After using the masks for the yellow on hull I actually had a lot more fun doing the rest free hand Cool
#68 Posted : 22 September 2015 08:51:20
BigGrin Looking good Dave lovely job Cool
#69 Posted : 23 September 2015 17:06:30
Thanks Martyn BigGrin
I have now 'blackened' the tracks using Ultimate Burnishing liquid, must say I am rather impressed with how they have turned out, even have rusty bits that make them look like they have been weathered a little. Very glad I took the advise and got some Fruil tracks Cool
I have also started to assemble them, its a slow process Blink but nothing too difficult just fiddly.
when I researched online how to assemble them it seemed that they always had a hole on one side for the pin to go through, these have a hole of both sides to stick the pin, this will take some thinking on how to get them connected when putting on the tank, hopefully as the pins are small shouldn't be too difficult.
Once the tracks are assembled I will also need to paint over the copper pins with a suitable colour as they are quite noticeable at the moment
Pictures with and without flash
#70 Posted : 23 September 2015 20:55:06
Hi looking good there dave.cam looks great and love the tracks.think ill try these tracks.cheers mick.BigGrin BigGrin
#71 Posted : 23 September 2015 23:23:44
Thanks Mick, they are great tracks and really easy to assemble if time consuming.
Well I have now finished the camouflage scheme BigGrin Where the colour call out said to use black I have gone with blac gray which I think matches the reference picture I have much more closely. I have done the black free hand again, I then went over the yellow very lightly to eliminate the overspray from the black gray and then again with the green for the same reason.
Next stage will be to apply the gloss and the decals before starting the weathering process. Im still not sure how I will go about this yet. I have ordered a filter to use and will start investigating the colours for the pin and panel wash so this might not be a very quick process.
Should I apply the decals before or after the filter?
I will also do a little bit to the tracks although I dont think much will be needed after the burnsihing liquid has done its thing.
The track you can see in the picture is only a 25 link run to test fit, and you can see where I will need to paint the copper pin ends.
#72 Posted : 28 September 2015 22:51:04
Due to working nights its taken a while to finish assembling the tracks but one side is now complete and the other side almost done too BigGrin I still need to sand down the pins and paint the copper to blend in.
The tanks has had its gloss coat added as well as the decals followed by another gloss coat to seal them in. I used Micro set and Micro sol to get the decals to conform to the rivet around the outside of the armour plate, those Trumpeter decals are tough things mind as it took several applications of the micro sol to get them to conform.
As you can see the tracks are just dry fitted, hence the pins, I needed to make sure I had the correct length BigGrin
Not much else I can do now until my filter and weathering washes arrive.
#73 Posted : 29 September 2015 09:18:08
BigGrin Cracking job Dave looking forward to the whethering Cool
#74 Posted : 29 September 2015 11:30:27
#75 Posted : 29 September 2015 17:08:00
Thanks Guys.
I'm going with Ultimate Weathering Washes with this, they have been ordered so should be here this week BigGrin
#76 Posted : 29 September 2015 19:31:30
BigGrin Very nice work DaveCool
#77 Posted : 29 September 2015 20:44:18
Very nice indeed!!!Drool ThumpUp
#78 Posted : 29 September 2015 21:32:14
Dave,
Great work love it well done.
Regards Trev.
#79 Posted : 29 September 2015 22:17:14
Thanks Andy, Nemesis & Trev
Tonight I started to have a play with the weathering washes that were delivered to my neighbour and only dropped round to me early this evening. No pictures yet, will wait until I get them on the model, they do seem very nice to use and I have a very rusted looking piece of plastic now that is also covered in a light dusting of mud LOL.
I've realised how much there is to do, still waiting on the filter I order, will probably make my next time.
#80 Posted : 30 September 2015 22:28:25
The tracks have now been rusted up nicely and installed on the tank.
I have also started to apply the filter but am not entitrely happy with it yet, Im thinking I should have applied a matt coat first rather than apply it over a gloss coat, will see how it looks once it is completely dry and apply more where needed BigGrin
5 Pages «<2345>
This page was generated in 0.208 seconds.
