shado Options
shado
#1 Posted : 20 September 2015 22:24:06
Rank: Newbie
Hi i am just starting my build with the 1st 2 parts and my 1st question is what are the 2 white liquids that come with part 1
#2 Posted : 21 September 2015 00:05:53
Hi Shado and a very warm welcome to the forum.... Can you post a pic of the 2 white liquids you are referring to. Cool Cool .. I'll see if I can get a definitive answer for you....
shado
#3 Posted : 21 September 2015 01:40:40
Rank: Newbie
Thanks Alan for warm welcome i am new to all this so bare with me please
photo's are a nogo i dont even have a cameraLOL
#4 Posted : 21 September 2015 12:27:29
I have pack 1 of the Akagi so have taken the photo, I havent opened it yet but looking at the instructions the one on the left appears to be a bottle of wood glue. There is no reference to the other pot which I am just guessing maybe some form of putty.
With regards to glue you may want to look at getting a large bottle of Aliphatic wood glue, for the metal parts a simple superglue would be sufficient or an epoxy if you prefered, although super glue would be much easier to work with.
#5 Posted : 21 September 2015 20:44:38
BigGrin Hi Shado
Firstly welcome to the forum and good luck with the build. The large bottle is PVA wood glue but I am unsure about the other bottle as I did not receive that one in my Kit. but I will get back to you on it.
#6 Posted : 21 September 2015 21:25:40
I opened up my pack 1 and had a look, the large pot is definately white pva glue.
I had another look through the instructions for pack 1 and would say the other pot is putty, if you look at the image below it says to use the putty supplied
Hope this helps
#7 Posted : 21 September 2015 21:31:37
BigGrin Hi Shado
The small pot is a model filler, it may be an idea to check its contents are ok before use.
shado
#8 Posted : 21 September 2015 23:51:18
Rank: Newbie
I did think 1 might be wood glue because of bottle shape, wondered if
the other was a refill doh thanks everyone for your help...
This page was generated in 0.160 seconds.
