Joined: 25/04/2010 Posts: 748 Points: 2,285 Location: bognor regis
WILL BE POSTING SOME PICS AS SOON AS I HAVE SORTED IT OUT...WATCH THIS SPACE cheers benny
 ok sorted it out and made a start.plans are a little vague but i am sure i will get there..anyway i have put her in a jig and installed the ribs cheers benny
next is the decks and the start of the first planking she is double planked so any mistakes can be sorted  cheers benny
hi jack first impressions are not that good but i am determined to get this one spot on..the ribs are not cut properly so i had some packing and shaping to do to get both sides the same cheers benny
Looking good so far Benny, and I agree with you about hiding any mistakes with the secondary planking, I had to totally rebuild the stern of the Cutty Sark, the secondary planking hid the changes perfectly. Good luck on your build and keep us posted...  Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
i have built the stand and added more first planks  cheers benny
i decided to add balsa fillers to the bow  cheers benny
Looking good.
in the instructions it says the whales are applied first..i have done the first whale and a few of planks which i have caulked...is this a good idea to caulk the planks on the hull? i also plan to apply a nail finish to the planks any thoughts would be appreciated  cheers benny
i have found this picture so i wont be oiling it now i will paint it as close to this as i can  cheers benny
Joined: 20/03/2010 Posts: 219 Points: 585 Location: Faversham
Looking good mate, if the hull planking on my mamoli victory turns out even half as good as this I will be very happy. I know what you mean with regards to the shortage of wood, looks like I'm in the same boat!! _____________________________________
Currently building:-
Amati Black Pearl
Mamoli HMS Victory 1:90 Scale
Caldercraft HMS Victory 1:72
jay7792 wrote:Looking good mate, if the hull planking on my mamoli victory turns out even half as good as this I will be very happy.
I know what you mean with regards to the shortage of wood, looks like I'm in the same boat!! i have wrestled with this since i started..are all mamolis like this..i started to plank the decks today and guess what..not enough planks..this will be going in the bin soon cheers benny
i have planked the top deck using the 3 plank stagger and gave it a coat of oil  cheers benny
