4 Pages 123>»
Arab Dhow by Artesania Latina Options
GilShapley
#1 Posted : 09 September 2015 21:28:52
After the Jupiter Build decided to go back to a small ship build. This is also to fill in time whilst waiting for the next issue of my Orrery build
The build so far as indicated by the attached pictures
1) The Box arrives
2) The contents of the Box
3) Attaching the frames to the false keel
4) another picture of the frames on the Keel
5) I have reinforced the frames by adding additional blocks to support the frames on the keel. Also to ensure the required 90 degree angle is achieved
6), 7) and 8) attaching the decks to the frame
9) Nailing the deck to the frames. I pre drilled the ply decks as I find this avoids the to potential for the deck to split
The next step is to shape the frames prior to planking
So far so good
More to follow
Current Build:-
#2 Posted : 09 September 2015 22:25:16
Looking great so far GIl.I have built a couple of AL kits and I thought they were pretty good.
#3 Posted : 09 September 2015 22:50:13
Perfect start. I really enjoyed this kit so I am sure you will
#4 Posted : 09 September 2015 23:19:27
Lovely start .
Looking forward to what's to come.BigGrin
#5 Posted : 09 September 2015 23:22:42
michael.rolph
#6 Posted : 09 September 2015 23:26:28
daffy09
#7 Posted : 10 September 2015 00:53:43
Hi Gil, this is a beautiful little model you've chosen and it's a real pleasure to build. I look forward to following this diary. Hope you get as much joy out of building it as I did.
Happy building
David
#8 Posted : 10 September 2015 10:48:57
BigGrin Lovely start this is a stunning kit to build ThumpUp
Hans
#9 Posted : 10 September 2015 13:38:55
Lovely clean build you have there Gil. Will be following with interest.
Rgds, Hans
Endeavour Cross section,D51
Completed: HMS Victory
GilShapley
#10 Posted : 23 December 2015 17:11:48
I have (Finally) completed the 1st Planking on the Dhow
The instruction advise a contact glue for the second planking
Any advice on which is best/easiest to use.
Confused Confused Confused Confused Confused Confused Confused
Current Build:-
#11 Posted : 23 December 2015 17:34:10
BigGrin Hi Gil
I generally use a medium thickness but be prepared to work fast with any contact glue. I put a line of glue along the planked hull then lay the plank making sure its butted up against the next plank before laying it. You may want to use Aliphatic for the 1st plank so you can lay it in the correct marked position, Once this is dry use contact for the rest of the planks pre shaping to fit before the final gluing.
daffy09
#12 Posted : 23 December 2015 18:32:45
Hi Gil
That's a lovely little kit you've chosen. I'm sure you'll get a lot of satisfaction from building this one as I have done. Jase did a build diary on this one which is great if you want something to refer to, and it was following his build that gave me the incentive to have a go at it myself.
I'll follow along with this diary with great interest. Look forward to the next instalment.
Happy building
David
riff-raff
#13 Posted : 24 December 2015 12:27:03
I've built this one myself, it's a great little kit and will make a nice addition to your collection. Good luck with the build.
Built:
GilShapley
#14 Posted : 24 December 2015 20:54:58
1st Planking Photos
Some minor filling will be required but in the end will be covered by the 2nd planking
Current Build:-
#15 Posted : 24 December 2015 21:06:59
Some really nice planking there Gil, looking good....Drool Drool .. Won't take too much filling or sanding to prepare for the second planking.... Well done...
#16 Posted : 30 December 2015 13:52:47
Hi Gil.
Looking realy nice. look forward to seeing your progress Ian Cool BigGrin
daffy09
#17 Posted : 30 December 2015 15:33:02
Nice work with the planking Gil. That hull is a beautiful shape, you're doing her proud. Well done
Happy building
David
GilShapley
#18 Posted : 05 January 2016 13:12:50
This build has been on the back burner whilst I considered my first attempt at second planking. I decided in the end not to use an impact glue (Lack of confidence) but continue with the evostick wood adhesive I have used for the rest of the build.
The hull has various curved surfaces so I have made up some formers which follow the curve of the hull at strategic places and use these to hold the planks whilst the glue dries . This glue goes off reasonably quickly but gives me time to position the plank.
Still some way to go but happy so far
BigGrin BigGrin BigGrin BigGrin BigGrin BigGrin BigGrin BigGrin
Pictures attached
Current Build:-
#19 Posted : 05 January 2016 13:35:11
Gil
Very nice work on this obe - its looking great.
Good choice with your second planking glue selection - I am hopeless with superglue tending to get more on myself than the parts i want to stick.
Hope the rest of the build goes well.
#20 Posted : 05 January 2016 18:19:24
BigGrin Lovely work on the planking Cool
4 Pages 123>»
This page was generated in 0.367 seconds.
