Rigging disorder Options
nightwisher
#1 Posted : 26 August 2015 22:10:43
Don't get me wrong, compared to other ships i have built the sovereign rigging instructions are very clear and easy to follow, but what I'm finding really annoying is some parts could have been fitted earlier before the rigging becomes congested. For example several belay pins are fitted to the rails beneath the shrouds and ratlines on the mainmast, almost impossible to drill straight holes here. There are numerous blocks fitted to the shrouds behind already fitted sails ,and 3 eyebolts to fit on the quarterdeck behind loads of lines (thanks for the heads up on this one martyn).I Posted this not to moan but to say if you have got all the issues it's worth reading ahead and maybe fit these parts earlier than instructed.
Had a dream to understand
A single grain of sand
He gave birth to poetry
But one day will cease to be
#2 Posted : 27 August 2015 00:33:10
Can't disagree with you really, does appear to be a little out of sequence in fitting some of the smaller parts.... Makes sense for those following on behind to have a good look at what's ahead and add these smaller pieces as soon as they can...Cool Cool
nickpink
#3 Posted : 27 August 2015 02:10:30
definitely agree with you there 😕
on the bench soverign of the seas & hms hood , collecting hms victory
#4 Posted : 30 August 2015 10:27:34
BigGrin Hi Nick the rigging of the SotS is a bit strange. A heads up on two more eye bolts that have to be fitted to the bottom of the masts to hold the ropes for the flags they are not to bad to fit on the main and the mizzenmast but a pain on the foremast hope this helps rgd Martyn
nightwisher
#5 Posted : 30 August 2015 12:49:24
Thanks martyn, missed those little fellas.
#6 Posted : 30 August 2015 13:08:10
Blushing oops sorry nightwisher replied to the wrong person but glad to be of assistance lolBigGrin
nickpink
#7 Posted : 30 August 2015 15:08:38
No cheers martyn will check that out too prob crack open 134& 135 before install more sails is that wise
#8 Posted : 30 August 2015 16:04:14
BigGrin I think I would just to get a heads up on whats next in the build Cool
nickpink
#9 Posted : 30 August 2015 20:13:44
Ah yeh heads up martyn yes good idea 👍🏻😉
nickpink
#10 Posted : 03 September 2015 05:29:48
Yes put flag eye bolts in cracked open 135 cheers 😀
#11 Posted : 03 September 2015 09:39:00
BigGrin well done on getting those little so and so's fitted Cool
Peter G
#12 Posted : 02 October 2015 03:00:06
Hi guys, a long way from rigging but would like to be prepared! Would appreciate to know what vols have these little fiddly bits in that should be fitted before the rigging. Regards, Peter G
#13 Posted : 02 October 2015 08:38:31
BigGrin Hi Peter you are a long way off the rigging but if you look at the official build issue 125 onwards it shows the belay pins etc and there placement Cool
