Pack 12 The parts The parts unwrapped, screwdrivers are always useful. The parts assembled, a small amount of cleaning up on the crankcase mating surfaces needed but nothing to worry about. A view of the underneath. And from above. Al Spal attached the following image(s):
 Rank: Pro  Groups: Registered
Joined: 27/06/2015 Posts: 104 Points: 305 Location: nottingham
 Hi Al, been watching your build for a while now, You are doing a great job. Regards Ian
 Hi Al Looking good, be careful with the mounting pins on the plastic window for the electronic pickup they can be on the fragile side. Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Thanks for looking in, Ian/Andy
Hi looking great coming along real nice.I'm one pack behind you.look forward to following as you enter the second half of your build.cheers mick. Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Looking good Al
Pack 13 The parts. A look at them unwrapped,only a few parts but they will make the engine progress a lot. A few pics of the parts assembled,everything went together as per the instructions and was a good fit. Thanks for looking Al Spal attached the following image(s):
Next parts have arrived. Parts unwrapped. Pics of the parts assembled, the wires to the plug caps are very fragile. Al Spal attached the following image(s):
 Hi Al nicely done, some replacement wires for the caps are provided toward the end if any of them need replacing or fixing Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Thanks Andy, I managed to break one Al
The next instalment. The parts unwrapped. The tank base added, I left the fuel tap off as I found it easier to fit the pipes to it before fitting. Starting to take shape now the engine is in. Indicator fitted to the other frame half. Thanks for looking Al Spal attached the following image(s):
 Looks great, the frame starts to give you a good idea of the size of this bike Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Thanks Andy, its certainly taking shape now Al
Hi Al.coming along very nicely.cheers mick. Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
mogwai wrote:Hi Al.coming along very nicely.cheers mick. Thanks Mick. Al
Looking good Al, very neat and clean work.... Regards Alan
Thanks for looking in Alan.
Pack 16 The parts, apart from the base parts which were missing. A better look at them. Tank base and ignition switch fitted. The next few pics are the testing of the lights and switches, I think they look pretty good. Thanks for looking Al Spal attached the following image(s):
 The lights certainly bring her to life , nice work Al Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Looking good with all the lights working
