New Printable Falcon Stickers Options
LrdSatyr8
#1 Posted : 24 August 2015 22:00:06
I've been working on these for awhile and still have alot of work left to do but thought that everyone might be interested in some replacement stickers for the Falcon that are much more accurate to the movie. They aren't for sale, they are free to anyone who wants to print them up and use them for their build... here's the differences between the two so far:
If you'd like to try them for yourself, here's the PDF I created for them...
https://www.dropbox.com/s/es5y0pghayiyz3z/DeAgo%20New%20Stickers.pdf?dl=0
All I ask in return is if you use them, take lots of pics and let me see them in action! I'm also working on better replacement for the main control console (including the raises level section and square monitor shroud) and am working on a matte for the lighting for both the sidewalls and the backwall for backlit lights. These can also be printed up as decals to be used as well. Lemme know what you think and I hope this helps!
RogerThornhill
#2 Posted : 25 August 2015 04:51:06
Can you use just a regular printer to print them out?
What paper is recommended for use with these and where can you get it.
LrdSatyr8
#3 Posted : 25 August 2015 14:13:58
Just regular paper can be used, but I highly recomend photo or card stock paper. You can also make decals if you wish. Just make sure to print at the best resolution you can. The better you print the better they will look. You can make your own decals by printing on glossy photo paper and then spraying with a clear coat once the ink is completely dry. Then cut them out and dip in water and they will slide off the paper easily. In any event you can do whatever you want with them.
This page was generated in 0.152 seconds.
