Solution for photos not showing - Admins please read Options
Wnt2Fly
#1 Posted : 24 August 2015 06:08:08
Rank: Amateur level 2
The issue with some images not appearing on firefox/chrome/ie is very easy to reproduce and within 5 minutes i've been able to figure out whats going on - this issue should not be happening and it should require a pretty simple fix on your end.
Essentially what is happening is the server is actually returning HTML instead of images, the contents of that HTML is "Please do not link directly to this resource. You must have a session in the forum." That tells me a few things.
What causes that
1. You are probably on a very old version of YAF, not recommended and probably a security risk. Your forum should be upgraded to the latest version.
2. Potentially your IIS server is configured to reject multiple that are quick and fast to a specific URL - this is most likely not the case.
3. YAF is having trouble with requests and the subsequent URL referrer sent with Chrome/Firefox/IE for images - This is the MOST LIKELY culprit. It could be that the YAF software isn't responding properly to the requests, or IIS has some configuration issue handling referrers. I can't replicate the issue in Safari 5.1.7.
Quick Fix:
1. in resource.ashx change
Code:
public void ProcessRequest( HttpContext context )
            // resource no longer works with dynamic compile...
            if ( context.Request.QueryString ["r"] != null )
                // resource request
                GetResource( context );
            else if(context.Request.UrlReferrer.Host.Equals(context.Request.Url.Host, StringComparison.InvariantCultureIgnoreCase)) //if ( context.Session ["lastvisit"] != null )
                if ( context.Request.QueryString ["u"] != null )
                    GetResponseLocalAvatar( context );
                else if ( context.Request.QueryString ["url"] != null && context.Request.QueryString ["width"] != null && context.Request.QueryString ["height"] != null )
                    GetResponseRemoteAvatar( context );
                else if ( context.Request.QueryString ["a"] != null )
                    GetResponseAttachment( context );
                else if ( context.Request.QueryString ["c"] != null && context.Session ["CaptchaImageText"] != null )
                    // captcha
                    GetResponseCaptcha( context );
                else if ( context.Request.QueryString ["s"] != null && context.Request.QueryString ["lang"] != null )
                    GetResponseGoogleSpell( context );
            else
                // they don't have a session...
                context.Response.Write("Please do not link directly to this resource. You must have a session in the forum.");
TO
Code:
                // resource request
                    // captcha
            else
This moves the processing of attachments outside of the URL referrer check. Also you can follow instructions here that will completely remove all referrer checks: http://www.yetanotherfor...sts/t8027-resource-ashx
Please see what you can do about fixing this error. not being able to see uploaded files is extremely annoying and impedes our ability to effectively share ideas and images. Feel free to have your team email me with questions.
-todd
michu
#2 Posted : 24 August 2015 08:45:01
Yeah that was my idea to, another thing is that caching headers are not set properly for caching images on the client which results in different set of images showing up every page refresh, instead of incrementally filling the gaps. Nothing is going to happen - the forum upgrade project is in the works for months and we just have to be patient, I guess...
Happy building :-)
greyhawk
#3 Posted : 24 August 2015 09:15:26
yeah, from what I've been seeing the forums are running on one of the YAF 1.9.x releases. Which is kinda like an open invitation to please come in and steal all the data, if you would be so kind.
greyhawk
#4 Posted : 21 September 2015 12:31:21
Someone apparently did something over the weekend. Picture attachments show up way more reliably. Not a 100% but way way better. Thank you for whatever you did.
michu
#5 Posted : 21 September 2015 12:42:51
Not for me though...
Still have missing pictures almost all the time. And it always had better and worse days (hours?). Possibly related to server load? It's particularly bad on a mobile.
Happy building :-)
z8000783
#6 Posted : 14 August 2023 20:47:19
Groups: Unapproved
For those that think I am a liar, an armchair warrior or that the problem is at my end . . .
Note the date.
admin
#7 Posted : 14 August 2023 20:51:30
Yep date noted 2015 not 2010 as you insisted
BYE BYE
Admin
z8000783
#8 Posted : 14 August 2023 21:02:06
Groups: Unapproved
BYE BYE
Admin
I said I had been a member of the forum since 2010.
"I've tried everything over the 10 years or so this has been happening. There is a fault in the forum S/W somewhere."
I also said that the problem had been around for 10 years. You are correct, I was wrong about that. It was 8 years.
My apologies.
admin
#9 Posted : 14 August 2023 21:43:45
For anyone reading this thread it appears that Z8000783 has his own interpretation of the Quote below from a previous post by him:
"I am not suggesting that there hasn't been improvements, there may well be for some, however, I am posting about my experiences here since I joined the forum in 2010."
There are several comments in post #6 that are a personnel attack on myself and that is a serious breach of the forum rules and to that end a full block has been applied.
I WILL hold a sensible conversation with anyone who has an issue, but keep on posting in a circular argument, mis quoting and then making a personal attack on myself or any Forum Support Team member or come to that any other member of this forum and the consequences will be the same.
Should anyone feel they need to speak to me about this on a personal level, then feel free to PM me at Admin. Just keep it civil.
Thankyou for your attention.
(Derek) Admin
This page was generated in 0.156 seconds.
