Maybe a solution to Rib 15a and 15b Options
Lonestar Spirit
#1 Posted : 16 September 2010 10:59:07
I been trying different ways to sort out the issue with parts 15A and 15b that are over-sized to the rest of the hull ribs, which would cause a bulge in the planking, it might not be a solution for everyone, but it does work on mine.
Take a scrap piece of timber and while pushing ribs 15A and 15b together (Towards each other) clamp the scrap piece of timber to the tops of each rib, to hole them in the correct place according to your other ribs as shown in the picture below, but be careful, if too much pressure is applied you could break the ribs.
This scrap piece of timber should be kept in place while planking the hull up to the top of the ribs, then when you take this scrap piece away, the ribs should now be held in place with no bulging of the planking.
As I said this may not be a solution for some of you, but I do hope it helps.
Best wishes
David
Ship Builds on the go
Mac
#2 Posted : 16 September 2010 11:54:52
Nice to see you back matey!BigGrin Great idea so simple. Do you think there is a chance of the pressure of ribs after release popping the planking as there is only going to be single planking?
Pam's shipyard is closed for now no more room!
willie
#3 Posted : 16 September 2010 12:24:27
for thoes brave enouth remove 15a and 15b from ship the part that glues on to the main frame below deck 7to out side of hull measure in 2mm at deck level then draw line to the outside of the hull notice it is taperd cut out also trim tab when replace it should line up with deck an rest of the frames for thoes how havent glued anny thing shohld be a doddle i had glued my frames but with a twist hear and there i got them out ok may have to play around with gun supportes
Lonestar Spirit
#4 Posted : 16 September 2010 16:30:27
I think it should be OK, and I'm not too sure, but there may be a deck to go onto these ribs, if so it will be even easier, as you can glue the now clamped ribs to the plywood deck, that will keep it in place, but again, not sure so will have to see what Tomick comes up with later in his build
Best wishes
David
Jack Sparrow
#5 Posted : 16 September 2010 17:16:49
It works a treat mate and I used some steam to soften them and I will leave it overnight to see if they spring back!!!BigGrin BigGrin
Lonestar Spirit
#6 Posted : 16 September 2010 17:34:10
SOME STEAM Blink Ooooo your getting a bit too professional now mate Flapper LOL I used Hope and Prayer lol LOL LOL I'm glad it's working for you, but like I said, I think the upper decking will hold them in place, well hopefully lol
#7 Posted : 16 September 2010 17:41:24
Hi David,
Great idea... I have slightly modified it. I made a cut halfway through the rib from behind with a razor saw. then ran thin superglue into the cut and clamped the plank in place like you until dry. Then after 2 minutes all done.
Chris...
Lonestar Spirit
#8 Posted : 16 September 2010 17:45:30
NICE!!!! that should sort this issue out once and for all I hope, and we can move on and forget about it.
Cheers for the added inspiration mate, well appreciated!!!!!!
cliffweld
#9 Posted : 16 September 2010 17:46:56
That looks like the route i'll take,i'll try it over the weekend.
CURRENT BUILDS
HMS HALIFAX
HMS BOUNTY
LYDIA EVA(STEAM DRIFTER)
MANTUA COASTAL CANON
COREL VICTORY CROSS SECTION
TAMIYA 1/35 MATILDA MK 2
HACHETTE TIGER TANK
DRAGON 1/35 TIGER TANK
This page was generated in 0.566 seconds.
