Hi
I am building the surprise and wondered what the Bridle Port on the bow was For?
Thanks. Chris..
On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Sorry Found it..
bridle-port, a square port cut in the bows on either side of the stem of wooden ships on main deck level through which mooring bridles were led. The same ports were used in sailing warships for guns, moved up from the gunport next abaft, when the ship was required to fire as nearly ahead as possible, as when chasing an enemy vessel. When used at sea for this purpose they were sometimes known as main deck chase-ports instead of bridle-ports.On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Joined: 13/10/2011 Posts: 851 Points: 2,628 Location: Leeds, Yorkshire
You didn't even see my lips move!! Mike T
Mike Turpin wrote:You didn't even see my lips move!! Mike T When you can actually build mine from your house, then I shall worry!!!!
 Rank: Pro  Groups: Registered
Joined: 30/03/2010 Posts: 285 Points: 880 Location: Belton, Norfolk
Jack Sparrow wrote:Mike Turpin wrote:You didn't even see my lips move!! Mike T When you can actually build mine from your house, then I shall worry!!!! Yeah  and I'd like to know where his hands were.......err......actually no I wouldn't
I wish I were a glow worm, A glow worm's never glum, 'Cause how can you be grumpy? When the sun shines out ya bum!!
