Yes. I found that. When I got the monocoque out this morning one of the tapes had come undone so I stuck it back down so just waiting to see if it holds. If it comes of again I might redo it with a fresh one. Do you know if there is more tape then we need. I know there's plenty left but don't know if we need any for the rest of the build. Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Front brake ducts and left radiator housing fitted.   Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Not sure if the tapes will be needed later on in the build but I suspect that there will be a couple of tapes spare. Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Yep, that one has come off again. Looks like I'll have to redo it. Anyway stage 56 finished now. Right side radiator housing and throttle bracket fitted.   Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
That's stage 57 and pack 16 finished. Injectors and fuel rails. Waiting for pack 17 now.   Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Marlboro decals added to the chassis.  Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Looking good Steve
Cheers Dave. The end is approaching. I'm thinking I will be a bit lost when this has finished as I should be finishing the mp4/23 about the same time so will have nothing to do after that. Although I have been eyeing up the rb7 especially as rc is more 'my thing'! Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Some excellent work going on here Steve, so neat and tidy, you should be very proud - well done!!
Kev
Cheers Kev Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Joined: 27/06/2011 Posts: 437 Points: 1,321 Location: milton keynes
great stuff Steve you must store her in a vacuum, cant see a speck of dust anywhere super clean and tidy regards Dan Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
Cheers Dan. This is how I store it(with a lid obviously!)  Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Pack 17. Turbos!  Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 58 done. Fuel pipes and left turbo charger started on.  Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 59. Right turbo started on, fuel pump and header tank hose.  Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
 Looking good Steve Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Cheers andy. That's stage 60 and pack 17 finished now. Wastegates  Oil/water heat exchanger fitted  Header tank  Engine and plenum sensors  Waiting for pack 18 now. Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Pack 18 here now, finally!  Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 61 started on. Nose box fitted to monocoque.  Engine fitted with header tank and plenum.  Intercooler to plenum pipes.  Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 61 completed. Engine fitted to the monocoque.   Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
