 Rank: Pro     Groups: Registered
Joined: 25/04/2014 Posts: 374 Points: 1,134 Location: Mandurah W.Australia
Hi Everyone I'm currently working through Issue 50 and from item 12 - glueing metal parts to the Transom. Can someone advise what type of glue to use as it is not defined? (metal to wood)... Kind regards JohnP
Hi John...I'm using super glue gel mate. As I am a bit iffy with superglue because the fumes causes flu symptoms with me, so I use the odourless Zap glue...Hope this helps..  Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Hi John, must admit I used superglue gel for most of the casting work but you may also like to consider quick drying epoxy, works just as well and gives you more wriggle time to get pieces set correctly....  .. Hope this helps. Regards Alan
Joined: 08/09/2012 Posts: 137 Points: 370 Location: derby
Super glue gel easy power I use alot 😉 on the bench soverign of the seas & hms hood , collecting hms victory
Easy power doesnt set straight away gives you about an extra min , min & 1/2 on the bench soverign of the seas & hms hood , collecting hms victory
Hi Guys Many thanks for the prompt responses with the info. I thought it would be super glue but needed to make sure. I have Loctite Super Gel here which I shall use. Much appreciate your help... Kind regards JohnP
