Joined: 28/07/2015 Posts: 42 Points: 122 Location: USA
Many of the parts are extremely small and difficult to work with. The detail is amazing, but at some point you have to realize that some stuff may not be seen very well. The levers for the control stack for instance, a complete )#*!!*$@ to put together and build! :)
They do look very fiddly in your pictures but you have done a fine job I am a little on the jealous side watching you build this
Hi Looks good from here. As for the fiddly bits, it's a good test of the eye sight. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
 Rank: Vice-Master       Groups: Registered
Joined: 07/01/2015 Posts: 856 Points: 2,479 Location: Sevenoaks, UK
I love fiddly bits :-) Going on holidays on Friday, maybe it will be released in UK by the time I'm back? For now I'm just sitting here and staring, green with envy. Any images I post on my personal builds are free to be used and shared under Creative Commons Attribution license, which means you can do what you want with them, on the condition you mention I'm the author.
Happy building :-) http://www.model-space.com/gb/
Nice work Wnt2Fly, well done and thanks for taking the time to show your work, I'll be watching with interest!!
Kev
Few other shots here... cockpit details are coming together nicely. File Attachment(s): Wnt2Fly attached the following image(s):
Those seats look pretty special, even better in the cockpit, brilliant work
Coming on nicely. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
As of tonight I've officially finished build pack #1.. I chose not to paint the prop, why they only give you one is beyond me; I'll wait for the 2nd one before I start working on them...if I'm going to get all the colors mixed and ready to paint I'll do both at the same time. Few points here, first the acetate windows are very nice but the instruction manual does not tell you there is a protective layer on them. So I actually used the windows opposite of where they were supposed to go, and when they were all in place I peeled off the protective layer. The fire extinguisher aluminium bands were one of those fiddly bits, probably the worst part of the build actually. I almost gave up and just glued it w/out the bands on them. The metal used for the windscreen and a few other parts is too thick. Bending them precisely, or heck, even cutting them out of the tree is a challenge with out damaging them. Sadly there is no room in the tree for a cutting tool, I will have to invest in a very very small cutter if the remaining kits continue to use such thick metal. The cockpit shows a detail painted between the upper control panel on the cockpit roof, this is not molded into the part nor is there any part or instructions showing what should go there. Also after all this work building the cockpit I though it was rather foolish that the instructions would tell you to glue the roof of the cockpit on!! There will be magnets holding the entire nose section to the fuselage, some sort of magnet system should have been devised to to hold this part on as well. I want to be able to open it up and look at my hard work, so I will never glue this - and will look to modify things appropriately so that it can be detached. With that said, I'm very happy with the kit, please take my comments as constructive, I'm pointing out just some minor improvements that can be done to the kit. I'm waiting on pack #2 and will start that a few days after it arrives. Until then, happy modeling!! -t Wnt2Fly attached the following image(s):
Another great update With regards to the window, were you trying to use a cutter to cut this out? I have used thick photo etch on a previous build and found that it cuts out fine using the same method as normal brass photo etch albeit with a little more effort. The method used was to place the part on a flat hard surface, like am bit of glass, ceramic tile or I use a small square of Perspex and then cut using a scalpel blade. With the thicker parts it just required 'rocking' the blade back and forth until cut through
Joined: 09/12/2013 Posts: 577 Points: 1,748 Location: smethwick england
Fantastic detail work  ,the thing that puts me off these partwork aeroplanes (apart from huge cost compared to plastic) is that most of the hard work and detail is covered up and will never be seen which is a real shame. Man he took his time in the sun Had a dream to understand A single grain of sand He gave birth to poetry But one day will cease to be Greet the last light of the library...We were here!
My first look at this build, its looking great well done. love the level of detail. this is definatly on my wish list will be following Jase “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
 Rank: Pro Groups: Registered
Joined: 08/05/2015 Posts: 239 Points: 693 Location: Wisconsin
Amazing work. Keep the pics coming. This will definitely be on my wish list.
davetwin wrote:Another great update With regards to the window, were you trying to use a cutter to cut this out? I have used thick photo etch on a previous build and found that it cuts out fine using the same method as normal brass photo etch albeit with a little more effort. The method used was to place the part on a flat hard surface, like am bit of glass, ceramic tile or I use a small square of Perspex and then cut using a scalpel blade. With the thicker parts it just required 'rocking' the blade back and forth until cut through I was using an X-acto blade and it couln't get through it. Its super thick, to be exact, its .3mm thick. Doesn't sound like much, but it won't cut easily. Also its not brass and it is super hard and tough. With a scrap piece in two pliers it took nearly 15-20 flexes back and forth to get a 2.5mm piece to break. Its like hardened steel!! I also use a model train track cutter, and that actually didn't work, the steel actually made the edges of the pliers separate instead of cut. -t
Looking fab, some really great work being shown... Very well done.... Regards Alan
Well well well.. look what arrived today... Wnt2Fly attached the following image(s):
Look forward to seeing some more of this one, the packaging looks good too Steve
Excellent work Wnt2Fly, the cockpit looks great. This is looking like a great build diary and definitely one to watch - well done on your build so far!!
Kev
 Nicely packaged Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Looking good. Look forward to seeing your work on pack 2. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Guest (6)
