John Passmore Options
John Passmore
#1 Posted : 14 August 2015 13:53:30
Hi Everyone
I'm currently working through Issue 50 and from item 12 - glueing metal parts to the Transom.
Can someone advise what type of glue to use as it is not defined? (metal to wood)...BigGrin
Kind regards
JohnP
jonny7england
#2 Posted : 14 August 2015 14:04:48
Hi John...I'm using super glue gel mate. As I am a bit iffy with superglue because the fumes causes flu symptoms with me, so I use the odourless Zap glue...Hope this helps..
Wink ThumpUp
#3 Posted : 14 August 2015 19:35:59
Hi John, must admit I used superglue gel for most of the casting work but you may also like to consider quick drying epoxy, works just as well and gives you more wriggle time to get pieces set correctly....Cool Cool .. Hope this helps.
nickpink
#4 Posted : 15 August 2015 00:06:33
Super glue gel easy power I use alot 😉
on the bench soverign of the seas & hms hood , collecting hms victory
nickpink
#5 Posted : 15 August 2015 00:09:20
Easy power doesnt set straight away gives you about an extra min , min & 1/2
John Passmore
#6 Posted : 15 August 2015 01:11:56
Hi Guys
Many thanks for the prompt responses with the info. I thought it would be super glue but needed to make sure. I have Loctite Super Gel here which I shall use.
Much appreciate your help...BigGrin
Kind regards
JohnP
This page was generated in 0.242 seconds.
