Tamiya 1/6 Honda CB 750 F Options
kpnuts
#1 Posted : 12 August 2015 21:18:57
Hi all well I enjoyed the last build of this, so here is my second bite at it, going to do it slightly different I am going to do it in a dio of a workshop with the engine out on the workbench and the tank and panels in the spray booth having a respray.
kpnuts
#2 Posted : 13 August 2015 20:43:42
Hi all made a start on the spray booth for the workshop, Dont look like much at the moment but I am going from memory and its been 20 plus years since i worked in a spray booth.
#3 Posted : 13 August 2015 23:52:23
Sounds like another interesting dio being done by you Ken, look forward to seeing how it all turns out...Cool Cool .. Have a feeling its going to be something good.....Cool Cool
kpnuts
#4 Posted : 14 August 2015 21:50:14
Hi all here is an update on this one.
#5 Posted : 15 August 2015 10:51:08
Love the colour Ken and the improvised spray booth.... Cool Cool .. Lovely work..
#6 Posted : 15 August 2015 15:11:08
Great start Ken, love the metallic blue colour Cool
kpnuts
#7 Posted : 16 August 2015 18:59:39
Hi all well I've added some more water to the back of the spray booth and made a bit more progress on the bike
kpnuts
#8 Posted : 17 August 2015 21:38:28
Hi all here is an update on this. My first of several problems I can forsee coming up The carb inlet openings are blanked off as they normally wouldn't normally be seen, as they are inside the airbox, os I've had to open them also since the cable are not connected I have to show the inner cables and the nipples on the ends of those, think I've opened a can of worms here, we will have to see what else crops up.
kpnuts
#9 Posted : 19 August 2015 20:37:45
Hi all as I said opened a whole bag of worms, of course with no tank or seat on the wiring loom would be visible, advice please does this look convincing ( obviously there would be loads more wires really but I don't have any thinner wire to hand and I don't want the loom to get too thick)
I realise I need to add the copper connectors to the end of the wires, and I realise the wires should be wrapped in black insulating tape, also the loom would not be tied with string, this I purely to check if its worth using this method.
#10 Posted : 19 August 2015 21:05:22
Looks good Ken, If you are not happy with the wiring loom you could always have it removed and just on the floor in a coil, wouldnt notice the wire thickness then - could be in preparation for a frame blast and spray?
I did make a wiring harness once by stripping out the fine copper wires from elec cable and spraying them various colours then twisting black wire round them as tie wrapsBigGrin
kpnuts
#11 Posted : 22 August 2015 20:29:41
Hi all here is another update on this one
#12 Posted : 22 August 2015 23:15:02
Starting to look a lot like a garage now, excellent work! Will you be putting in a bike lift as well for the frame to sit on? I think that would look pretty cool Cool
kpnuts
#13 Posted : 24 August 2015 20:57:29
#14 Posted : 24 August 2015 22:16:57
Nice work on the tool box Ken, loving your posters LOL
kpnuts
#15 Posted : 26 August 2015 20:39:56
Hi all here is tonight's update
and this will end up being my bottle of WD40
#16 Posted : 26 August 2015 22:12:33
Awesome work Ken, are the tools all scratch built?
kpnuts
#17 Posted : 26 August 2015 22:45:08
Yep got to try and figure out how to make a socket and rachet or two.
kpnuts
#18 Posted : 30 August 2015 21:46:29
Hi all another update on this one.
I've weathered the tyres a bit
kpnuts
#19 Posted : 31 August 2015 18:28:05
another little update on this one.
#20 Posted : 31 August 2015 18:31:09
Nice work again Ken! Did you have any luck coming up with a method for the socket and ratchet?
