18 Pages «<1415161718>
Caldercraft H.M.S Agamemnon Options
#301 Posted : 06 August 2015 17:45:31
BigGrin Hi Trev, Alan and Martyn
Thanks for looking in and your comments,
The problem with iron bolt corrosion was finally solved when a mixture of copper and Zinc that was hot rolled to give it strength was used to replace the iron bolts but this still did not stop the foundering of the ships Ramillies [97 guns ] and the Centeur [74 guns] off the Newfoundland coast.
AndyCool Cool
#302 Posted : 07 August 2015 13:40:30
Hi looking great Andy.must admit was not to sure on weatherin on tiles at first.but now had few looks at it I actually do like it.cheers mick.
#303 Posted : 07 August 2015 20:23:59
BigGrin Hi Mick
Thanks for looking in and your comments, I guess the look is a little shocking compared with the normal weathered look that is most often produced that is more akin to the look of Muntz metal [60% copper,40% Zinc ] weathered sheathing a perfect example of Muntz metal sheathing can be seen on the Cutty Sark.
#304 Posted : 07 August 2015 23:07:57
BigGrin Hi All
Just a couple of pic's to show the finish on the copper eye bolts when using the Liver of Sulfer Gel, It gives a darkgrey/black almost pastel shade that is quite pleasing.
#305 Posted : 08 August 2015 08:31:05
That stuff works Andy very nice shade and will add to the finish
Trev.
#306 Posted : 08 August 2015 21:36:47
BigGrin Hi Trev
Thanks for looking in and your comments, the gel reacts almost instantly on pure copper and takes a little longer on alloys such as brass. It has the added bonus that the degraded solution [ after a days use] can be used as a fertilizer, tomato plants love it apparently.
#307 Posted : 09 August 2015 21:35:50
BigGrin Hi All
I am now half way through making up the 26 18-pounder gun carriages they come pre cut an a sheet of walnut ply that also has the 9-pounder carriages on it. The assembly is quite straight forward the clean up before assemble takes the timeBlink . I have painted one red so far and there is more furniture to add to each carriage yet and note the square axles in round wooden wheel holesLOL . More soon.
#308 Posted : 09 August 2015 22:01:18
#309 Posted : 09 August 2015 23:16:47
BigGrin BigGrin Hi Steve
Thanks for looking in and your comments, I will be using a blackener on the cannon but I am awaiting the arrival of the ultrasonic cleaner before I do it , I have krick and the sulfer gel to do it. The brass cannon have been sitting in bags for a good few years so the protective coating/oil has I think hardened off as when I did the lower stub cannon I had mixed results even though the cannon were degreased and scrubbed with a scourer. Hopefully the ultrasonics will take it off.
#310 Posted : 10 August 2015 21:50:42
BigGrin All the gun carriages built so far have been painted nowCool Penny shot includedDrool LOL Drool
#311 Posted : 11 August 2015 00:17:30
Cannons look great Andy and I do love the square axles into the round wheel holes....LOL LOL .. Maybe the wheels should have been square too.....LOL LOL .. Fab work as usual...
#312 Posted : 11 August 2015 01:34:42
Those cannons look pretty amazing Cool
#313 Posted : 11 August 2015 15:21:57
BigGrin Lovely work Andy ThumpUp ThumpUp
#314 Posted : 11 August 2015 20:12:56
BigGrin Thanks everyone for looking in and your comments, the square axles I think were done for a reason this being only 4 points rubbed against the round hole for the axle so cutting down on friction so movement during loading was easyer.Cool
#315 Posted : 16 August 2015 19:07:52
BigGrin Hi All
All the 24lb cannon carriages have now been made up and painted along with the cannons themselves, right now I am trimming the etch trunion straps and shaping them the fit the trunions after shaping all 40 they will be rediped in blackener before fitting. Five have been finished to this point so just 21 left to do. Four of the 12 9lb gun carriages have been made up also. The last few pics show the cannon on the deck which certainly makes it a lot busyer although there is lots more furniture to add to the carriages like the flintlocks and tackles. More soon.
#316 Posted : 16 August 2015 22:55:16
cannons look great Andy and that deck is really starting to look business like Cool
Pinks666
#317 Posted : 16 August 2015 23:37:28
a really intricate build. I like looking at builds like this that show time spent on making the small details look really smart, i enjoyed looking through this diary.
Marc Heeley
#318 Posted : 17 August 2015 20:57:31
BigGrin Thanks for looking in and your comments both of you and im glad you enjoyed the diary much apreciatedCool
#319 Posted : 17 August 2015 22:49:16
This looking awesome, it really adds character with all those cannons added
#320 Posted : 17 August 2015 23:45:05
Guest (10)
This page was generated in 0.247 seconds.
