7 Pages <1234>»
San Francisco II build by Arek (first wooden ship build) Options
#21 Posted : 09 August 2015 00:08:59
#22 Posted : 09 August 2015 00:13:03
This is turning out to be a really interesting project to follow. Looking forward to seeing how it all works out.....Cool Cool . Very well done...
#23 Posted : 09 August 2015 01:20:04
BigGrin The lights look great and should set her off atreatCool
#24 Posted : 09 August 2015 03:20:52
arek wrote:
It took me some time but wiring of my SF is almost over!BigGrin
I used a variable resistor for the entire system and now I have a complete control over LED brightness (again thanks to WildRover for advice). When resistor is set at a minimum my camera was not able to catch the light so I'm happy. When I was looking for resistor I came across a remote control switch and I decided to use it as well . The problem is that to many elements have to be installed in the hull and yet I have to make room for dummy canons so the battery holder, variable resistor and sensor for remote switch I will to install in ship stand.
I have to admit, the building becomes more complicated than I thought.Cursing It looks like I'll have to build the boxes around some of the LED lights that the light is not leaked by some parts of the ship and plan carefully placement of the dummy cannons.
It will be a long way before I even start planking the hull .....but seeing all this adds-on working is very rewarding.Cool Cool
Really nice work! I dont suppose you have a link to where you purchased the remote control from?
arek
#25 Posted : 09 August 2015 11:19:28
jase wrote:
You certainly have a good end result. is the intention to see the light from the gratings?
If you are adding dumb cannons you will have to build boxes for each one, so as long as you carefully seal them that should stop any light leaking through.
Following with great interest
Hi Jase, thanks for stooping by.BigGrin
Yes, the light is going too be seen from the each grating as I showed in this post but will be more dim
As for the dummy cannons I was thinking to add support beams along the way (similar to SotS) from balsa wood to not have problems when fairing the hull.
So far I'm waiting for dummy cannons to be delivered, when I have them then I will decide what way to fit them.Confused
arek
#26 Posted : 09 August 2015 11:23:11
HI davetwin,
You will find remote controll here- http://www.ebay.ie/itm/3...Name=STRK%3AMEBIDX%3AIT
arek
#27 Posted : 09 August 2015 21:34:52
Hi all, need help from someone who finished this build.
I'am working now on gun-ports position.Confused Confused
To make sure where to place support beams or boxes for my dummy cannons I've made some kind of template taking measurements from overall plan.Blushing
As this is very important for my build can any one who finished SF can confirm my measurements shown on the photo below? Most important is the distance between lower and upper row.
arek attached the following image(s):
arek
#28 Posted : 12 August 2015 21:24:58
My dummy cannons finally arrived!
They have slightly different front, but with little of grinding and drilling they look very similar. One is finished 21 more need to be done !
#29 Posted : 12 August 2015 22:30:33
BigGrin Nice looking cannonsCool
#30 Posted : 13 August 2015 08:20:56
Hi Arek, yes all the ports look in the correct position. Just comparing with the side of mine and looks pretty much.
I do like you idea of the dummy cannons.
Chris.
#31 Posted : 13 August 2015 11:49:55
arek
#32 Posted : 13 August 2015 18:59:01
Chris.
Hi Chris,
Thank you so much for taking your time to check measurement on your model.
So when I have that confirmed should start building some supports for cannons during the weekend.BigGrin BigGrin
arek
#33 Posted : 15 August 2015 10:57:48
Hi Everyone. BigGrin
I started to working on the dummy cannon supports.
For back strip where cannon is mounted I use 3mm plywood, height of the strip is about 17 mm h to give me some room for errors.Cool As for top and bottom strips balsa is handy.
I decided to use one long strip for the top roll.
Bottom roll is going to be made from small pieces glued between frames. Each piece have to be cut and shaped individually.
To ensure that they are installed at the same depth and height i made small jig witch rally helped a lot.
]http://[/url]
#34 Posted : 15 August 2015 11:07:21
Very nice, great improvisation too....Cool Cool Look forward to your next update...
#35 Posted : 15 August 2015 12:38:05
BigGrin Nicely done and great workCool
#36 Posted : 15 August 2015 15:22:57
Nice work, great idea with the jig it looks like it worked a treat ThumpUp
arek
#37 Posted : 21 August 2015 17:42:32
Thanks all for stopping by and kind comments!
There should be some updates this weekend!
arek
#38 Posted : 24 August 2015 20:10:49
Hello everyone,
Small update but loads of work was involved.
After gluing all pieces between frames, I simply cut excess of balsa with craft knife and finished witch sand paper in similar way that fairing the hull. When have all that done just painted inside witch black paint. Next step is to finally glue in rest of the decks .....
arek
#39 Posted : 02 April 2018 09:28:41
Hi All,
It has been a very long time since my last post but there was so many things happening in my personal life. My ship was safely storedCool but not abandoned and I'm back now to the build witch new ideas.BigGrin BigGrin
I decided to add some windows to took advantage of all work that I put into adding lights in to my build. Im not really sure how historically accurate is the placement and look of them but this build is more about learning and checking my skills.
I started working on the bulkheads fitting windows and dors first then I worked around them. I decided to replace metal dors that comes with the kit, they only dry fitted for the moment as I'm still working on details.
#40 Posted : 02 April 2018 09:46:54
Looks really good, hope we see some more of your build very soon....Cool Cool
7 Pages <1234>»
This page was generated in 0.200 seconds.
