RB7 ENGINE Options
Padidiver100
#1 Posted : 08 August 2015 23:36:27
Rank: Newbie
Hi I need help with my seb vettle engine on the RB7 I have built the engine but the piston jams in the housing
I followed the instructions with the piston and the housing that goes in to the engine the piston goes in fine but as soon as the piston comes up it jams and brings up the housing and stops
what can I do to fix this problem
hope you can help me
thanks
#2 Posted : 08 August 2015 23:57:22
BigGrin Hi Padidiver
If your engine is sticking at TDC or Top Dead Centre then this is perfectly normal and it will free up during the run in period, If it is sticking at BDC or Bottom Dead Centre then you have either got the cylinder or piston the wrong way around and its a simple case of just reversing the parts. I have added some links to other posts that have had the same problem.
http://forum.model-space...spx?g=posts&t=12278
http://forum.model-space...spx?g=posts&t=16131
Hope this helps.
This page was generated in 0.256 seconds.
