7 Pages «<4567>
Stevie's "Panart Armed Launch 1803" Options
#101 Posted : 29 July 2015 00:32:33
Wonderful Steve, truly outstanding.....Cool Cool
#102 Posted : 29 July 2015 08:09:39
BigGrin Stunning work as always Stevie I am loving this build Love
Hans
#103 Posted : 29 July 2015 09:40:17
Wow, stunning craftsmanship. Looking the part and beautiful work.
Rgds, Hans
Endeavour Cross section,D51
Completed: HMS Victory
#104 Posted : 29 July 2015 12:16:15
I'm really loving the way all the different coloured woods work together, stunning!
#105 Posted : 02 August 2015 14:29:27
Thanks for the commentsBigGrin
A bit more progress, firstly, made a start on the main cannon - the wooden parts for this were plywood and not a good look. I didnt have any walnut sheet so decided to veneer the parts with walnut instead, came out ok - certainly better than ply anyway. Very surprised that these were not walnut in the first place when you think of how much walnut was supplied, practically all the insides are made from it!
Next it was time to cut, shape and fit the 6 benches and brackets. This went quite smoothly apart from bench 3 (with the mast hole) As this bench had to line up exactly with the base mast hole I couldnt have it fitted directly over a rib like the other benches, it would have helped if this was mentioned when fitting the base block but the instructions didnt even say exactly where the hole in the base block should beConfused
Nevermind, It's prob only me that will notice itLaugh
This was also a good time to give it a coat of Georgian Oak danish oil tooBigGrin
#106 Posted : 02 August 2015 16:05:52
BigGrin Looking goodCool
#107 Posted : 02 August 2015 16:58:32
Going great Steve. Your doing excellent job. BigGrin
#108 Posted : 02 August 2015 21:51:51
Oooh I like those benches Cool
#109 Posted : 03 August 2015 08:51:05
BigGrin Wow what can I say lovely job simply bril Love
Hans
#110 Posted : 03 August 2015 13:21:37
Superb work there Steve, looking great.
Rgds, Hans
jonny7england
#111 Posted : 03 August 2015 14:55:16
Amazin piece of workmanship!! It almost looks real!! Love it to bits!!
OhMyGod Love ThumpUp
#112 Posted : 04 August 2015 00:06:25
Top notch work Steve, she looks wonderful....Love Love
michu
#113 Posted : 04 August 2015 00:36:03
Steve, this is a tribute to our craft. Beautiful work, I've started to looking forward for each your update. Thanks for sharing this beauty.
Happy building :-)
#114 Posted : 05 August 2015 15:41:01
Thanks guys, the comments mean a lotBigGrin
I dont like making accessories for models, I like making them even less at the end of a build so I have decided to get them all out of the way at this stage and then I can forget about them.
There are a lot of bits to add to this build and they are all mostly made from scratch using the plans and instructions. There are 6 baskets / buckets, various cannon loading and cleaning tools, boat hook and a lot of oars, 12 I thinkAngry
So, the next few posts will be showing the add-ons - the last couple of sessions I have been making the water bucket and the powder charges basket, containing the charges in 2 calibres.
These were made by using 2 discs and planking the sides, the top disc was not glued in place as this needed to be removed when the plank glue had dried. They were then stained and rope wrapped. The water bucket has some clear casting resin inside to look like water.
There is also going to be an anchor cable basket, rag basket, cannon ball trays and basket.
The tools made so far are a cleaning swab, a rag scooper to retrieve the old rag wadding from the barrel, a cannon ball scoop, a boat hook and push rod to compress the charge and wadding.
All the tools are for the big gun, not sure if I will make a set for the small guns yet, no mention of it in the plans anyway. More soon!
#115 Posted : 05 August 2015 18:29:53
You might not like building the accessories but you you have certainly done a pretty fine job on them as they look fantastic Cool
#116 Posted : 05 August 2015 19:04:50
BigGrin Lovely work yet again Stevie Cool
#117 Posted : 06 August 2015 00:12:47
Great work on the accessories Stevie, I especially like the buckets, very well constructed and looks fab....Cool Cool ..
#118 Posted : 07 August 2015 13:43:28
Hi simply stunning workmanship on display here.very well done, just love this build.a real joy to follow.cheers mick.BigGrin BigGrin
daffy09
#119 Posted : 07 August 2015 14:22:12
Beautiful work Steve, and I especially like the bucket complete with water, a nice touch.
Happy building
David
#120 Posted : 10 August 2015 22:17:33
Awesome work. You have done great work on the launch.
Chris.
7 Pages «<4567>
