Joined: 07/09/2010 Posts: 83 Points: 285 Location: portsmouth
hi all new to this but i was thinking of puting light inside the build,as ive seen it done on other builds but not sure of the best way of doing this. Can any one give me any ideas, had thought about puting in flashing exmas lights in be hind the gun ports,but would like to light the back cabin as static lights ? Any help or ideas would be a help Thanks Brian Brian
Current Builds HMS Victory HMB Endeavour HMS Hood PLAY UP POMPEY!!!no wise cracks
 Rank: Pro  Groups: Registered
Joined: 20/03/2010 Posts: 278 Points: 833 Location: Nottingham
Welcome aboard Matey!  some of the guys were discussing this a couple of months ago but no one has got round yet to posting details wiring diagrams etc as things have been a bit crazey round here. But there is a lot of expertise on this forum so no doubt one of the guys will be along to help u in a bit. Pam's shipyard is closed for now no more room!
Joined: 19/03/2010 Posts: 602 Points: 1,679 Location: Lincs
I have started just using simple LEDs from Maplins http://forum.model-space...t.aspx?g=posts&t=993You do not need a parachute to skydive. You only need a parachute to skydive twice.
Built: Golden Star, English Brig. RMS Titanic. (Academy 1/400 Centenary Anniversary Edition) Revell-Monogram 1/48 B-29 Superfortress 1:8 Baron von Richthofen's Fokker Tri-plane. HMS Victory. Nelsons Flag Ship. Sultan Arab Dhow. Artesania Latina Carmen II. The Battleship Yamato. Model Airways Wright Flyer 1:16 Scale. Trumpeter Bismarck 1/200. HMS Sovereign of the Seas. The Black Pearl.
[quote=riff-raff]I have started just using simple LEDs from Maplins http://forum.model-space....aspx?g=posts&t=993[/quote] U no matey I must be getting dafter in my old age  Of course u put Leds in ur cutaway in August  Sorry! Pam's shipyard is closed for now no more room!
Just finished wiring the LEDs to the mains via a 12v power pack. I was using a 12v battery box that I didn't like as I would have to have access to the pack to change the batteries. I have used the power pack from an old radio which plugs into the ship via a round 6mm socket so all I have to do is mount the socket somewhere discrete. I have mounted the LEDs using small block connectors. That way I can bend the LED wires into the exact position that I want them in. I just run the wires where they can't be seen. Obviously this does require some drilling of the gun decks. If you are going to follow this example - the best tip is to use very thin wires as you need to bend some round tight corners. Another tip - if you are buying your LEDs from Maplins, decide roughly how many you need. They only stock 2 - 4 of any kind !!!! You do not need a parachute to skydive. You only need a parachute to skydive twice.
thanks for the adivce Riff Raff this is a great help as ive got an old dolls house lighting transformer that i will use,did try some of the dolls house bulbs as well but found these were to bright,if pos can you let me know the Maplin part No of the led,s you used,and do they do them in flicker style  . Thanks Brian Brian
Joined: 26/03/2010 Posts: 600 Points: 1,959 Location: Solway West Cumbria
Hi bripfc.....i do not know if they do a flicker l.e.d.....but you can get a variable resistor .....that will dimm the bulbs....they work like a dimmer switch...hope this helps... .John...
thanks for that snowtiger have found some that flash from maplin might give these a go see if work, has any one got a diagram of whow to run the wiring insde Brian
I just run them where I can - I decide first where I want illumination fix the LED to a block connector and then just run wires where I can. Numbers on the pack of LEDs are: 63.05.B4 CJ68 048-0077483 Hope this helps mate You do not need a parachute to skydive. You only need a parachute to skydive twice.
Hi rif raf did you put any resistors in the wiring for led as ive got some led from maplin and i had a dolls house transformer 12v it ca take up to 35 lights but tried it an it blew the leds any ideas why? any help or ideas would be good Cheers brian Brian
I did at first when I used 6v LEDs but then I changed to 12v LEDs with a 12v power supply. You do not need a parachute to skydive. You only need a parachute to skydive twice.
does any know what type of resistor i would need to use as have bought all the led i need, the other half wasnty to happy then, so hate to think what she will say if have to replace again? Brian
