7 Pages <12345>»
Airfix royal sovereign Options
#41 Posted : 10 July 2015 23:51:41
She's certainly coming along Ken, lovely work as usual....Cool Cool
#42 Posted : 11 July 2015 08:27:26
BigGrin lovely work Ken coming along a treat ThumpUp
kpnuts
#43 Posted : 12 July 2015 16:24:52
Hi all I've decided to do something different with this and it involves this
It flickers just like a real candle and the other one is kaput so I developed a cunning plan so, off with the transom
can you guess where this is going
drilled out the windows
then removed the rest of the window
yes thats right I'm going to RC it, only joking, lighting up the state cabins.
kpnuts
#44 Posted : 19 July 2015 20:48:54
Hi all a small update on this, The transom sticks out past the gallaries on the sides and I didnt like the way Airfix just moulded them flat so I've rounded the edges and reguilded them
also the grills on the prow are not moulded all the way through so I drilled all the holes out.
and I've hacked the candle apart and reconfigured it
#45 Posted : 19 July 2015 22:10:49
Nice work Ken, that LED should look pretty cool when its in Cool
kpnuts
#46 Posted : 22 July 2015 19:03:00
Hi all here is another update on her
#47 Posted : 22 July 2015 21:20:21
Hi Ken!
Beautiful work on those lights, it really sets off the stern a treat!Cool If you have any of that plastic mesh like I had with the DelPrado (supposed to be gratings if you ever did!)BigGrin you could try gluing it to the inside of the drilled out windows to simulate the leaded glass. Also, just in case you decided to add more lamps, Poundland sometimes have a set of three battery powered tea-lights with the same flickery effect - guess how much they are!LOL
She's coming on great Kev, well done M8!
Robin
#48 Posted : 22 July 2015 22:16:14
Nicely done Ken, looks great Cool
kpnuts
#49 Posted : 26 July 2015 18:08:29
Hi all here is another update on this lovely little kit, it really is a joy to build.
kpnuts
#50 Posted : 27 July 2015 21:05:35
Hi all here is tonights update
can anyone tell me did the banding on the masts go on the next section too, I cant find any pics where I can see that bit.
Also on the side that is not firing would the cannons on the top deck be poking out the gun ports or be inside the gun port, I think Airfix made a mistake with one of the top deck gun ports as you cant get the cannon out of the gun port as the stairs are in the way.
greyhawk
#51 Posted : 27 July 2015 21:27:23
Apparently not, at least according to Willem van de Velde.
#52 Posted : 27 July 2015 23:56:22
Looking good Ken, think you're doing a great job with this kit.... Very nicely done.....Cool Cool .. As for the banding, it only appears on the lower mast sections of the main and foremasts.... Cool Cool .. Hope this helps..
#53 Posted : 28 July 2015 00:54:35
Lovely work Ken ThumpUp
kpnuts
#54 Posted : 29 July 2015 21:34:33
Hi all here is tonights update, I've tried to do the cannon anchors and the ammo boxes.
also tried an experiment with the vac formed sails
which looks most realistic
#55 Posted : 29 July 2015 22:45:25
Looking good Ken, love how the sails turned out Cool
#56 Posted : 30 July 2015 07:54:40
BigGrin Very nice work on the sails they look better than the kit ones ThumpUp
#57 Posted : 30 July 2015 09:28:12
Big improvement on the sails and well thought out.....Cool Cool .. Looing good.....Cool Cool
kpnuts
#58 Posted : 09 August 2015 19:44:34
Hi all here is an update on this one. All the guns in place (still got to tie some down) all the closed gunports glued in.
I've discovered that the slots in the grating for the bowsprit tie downs are not there so had to make them.
#59 Posted : 09 August 2015 21:05:16
BigGrin very nice work Ken she is coming a long a treat Cool
#60 Posted : 09 August 2015 23:59:27
Looks great Ken, think you've done a great job with this kit.... Very well done....
7 Pages <12345>»
