16 Pages «<141516
ARPurchase's build of the D51 Options
mikey
#301 Posted : 26 July 2015 12:27:52
Very impressive model, if mine looks half as good as yours Andy I will be well pleased.
Regards Mike
Current Build`s
Sovereign of the sea`s
HMS Victory x section
D51 Locomotive
Spitfire
Harley Davidson Fat Boy
Mantua titanic
#302 Posted : 26 July 2015 13:04:23
BigGrin Hi Mikey
Thanks for your comments and looking in, Im sure your D51 will be a model to be proud of when its finished.
oldsid
#303 Posted : 24 July 2016 03:32:22
Stage 28 Page 61 in the instructions, it shows the left eccentric arm adjusted 10 degrees left of vertical with the pin at 6:00 o'clock. I can't find any place where it says how the right side eccentric arm should be adjusted. Can you help me out. I'm missing it somewhere.
Thanks, Sid
#304 Posted : 24 July 2016 07:44:13
Hi Sid
Just set the eccentric arm up the same on the other side
oldsid
#305 Posted : 24 July 2016 14:25:22
Thanks, Andy. That's what I figured, but just wanted to check to see if I was right. Thanks again.
Sid
16 Pages «<141516
This page was generated in 0.139 seconds.
