Lighting the SOS Options
MikeL
#1 Posted : 23 July 2015 02:15:41
Rank: Amateur level 2
I have just begun my journey with the SOS. But as I'm planning my build, I am wondering about lighting. Does anyone have information about authentic lighting aboard a vessel such as this? I'm thinking LEDs in lanterns (I've found some really nice, extremely small flickering flame LEDs) but don't know where the placement should be. Since I've not begun my build, is there someone who's been there, done that, who could tell me where best to place my lighting pathways or give me ideas about a lighting harness? When I've looked at the pictures, I haven't been able to see where the lighting would have been, and then, on which decks the lighting would be visible to the observer of the model.
I'm curious, were there open fires, or did they use lanterns to light their punks to set off the fuses on the canons?
Any help would be greatly appreciated.
highdobb
#2 Posted : 23 July 2015 07:38:42
Rank: Newbie
I'm just starting the build soon as well. I will be interested in adding LED's to mine also. I'll let you know if I find anything through my research as far as historically accurate lighting. I'm planning on fudging it a little regardless, I just want it to look awesome! (Not that it won't be awesome even unlit!)
#3 Posted : 23 July 2015 08:10:10
BigGrin Hi highdobb and Mike welcome to the forum BigGrin
I have not put LEDs in mine but there are some builds on hear that have. Look At Robbyrobs build ThumpUp
Ships in the 16 hundreds where lit by a mixture of lanterns and candles and more ships where lost to fire than in battle Crying
Looking forward to your builds rgd Martyn
#4 Posted : 23 July 2015 10:34:45
Hi Mike, great to hear you've started your journey with this build and hope we get the chance to follow your progress...Cool Cool .. I would think most of the lanterns during that period would have been hand held and simply moved around and suspended from the joists etc wherever they were needed, very few would have been permanant fixtures. I believe Karl toyed around with lighting his gunports with low level LED's installed on the sides of the ribs in front of the dummy gun supports, to produce a flickering glow in the ports themselves. He didn't move any further forward other than installing the led's for test purposes. May be worth having a look through the early stages of his diary too...Cool Cool Hope this helps..
Gibbo
#5 Posted : 23 July 2015 12:08:07
Hi Mike
welcome to the forum, This link sends you to Spark's DelPrado re-fit of HMS Victory, he has lit this ship, I know it's a different ship but it might give you some ideas you never know.
Cheers
Paul
http://forum.model-space....aspx?g=posts&t=6768
MikeL
#6 Posted : 24 July 2015 01:19:03
Thank you to highdobb, Marty Ingram, Gandale and Gibbo for your insights and tips. Since this is my first ship, I hope you'll follow me and advise me on the build. I am hoping to start a build log soon. I just picked up an oak stair tread to mount the ship on. Right now I'm figuring out how I'll run my wires from the ship to the base. I hope to be able to show how I'm going to do it soon. Along with LED lighting, I'm thinking about adding sound and inserting a speaker into the ship (water lapping, sails flapping, gulls crying and officers giving orders). I've added scale sound to my model railroad and it really does make a difference - it is well worth the extra effort, in my opinion.
Gibbo
#7 Posted : 24 July 2015 01:37:38
Wow, i'm looking forward to that.Drool Drool
MikeL
#8 Posted : 02 August 2015 01:46:16
I've been thinking long and hard about how I'm going to add sound and lighting to my Sovereign of the Seas. I have finally decided to use 4 lighting circuits - 2 toward the bow, and 2 toward the stern. I will use 3 speakers for sound. The largest speaker will be in the center of the ship and two smaller ones will be mounted forward and aft and higher (one in the gallery and one in the forecastle). The sound and light board, along with the amplifier will be mounted under the display table. The first thing I had to decide was how to run the wires to the inside of the ship. I decided to use the threaded pipe that comes in lamps and I re-threaded it to add T-nuts. I cut out an area on the spine of the ship and reinforced it to accommodate the T-nus. I found some polished brass tubing that fit over the threaded pipe. I haven't determined a final length for the pipes yet.
MikeL attached the following image(s):
MikeL
#9 Posted : 02 August 2015 01:52:50
Forgot to include the picture that shows the pipes with the brass tubing.
#10 Posted : 02 August 2015 09:53:21
Very interesting Mike and looks like a good solution for lights and sound, will be following with interest....Cool Cool.. As it looks as if you're not using a build jig you'll need to be extra careful to ensure the keel stays absolutely straight and true, especially during the early planking phase.....Cool Cool ..
#11 Posted : 02 August 2015 10:24:03
BigGrin Lovely job I wouldnt know where to start with all the wires Confused
#12 Posted : 02 August 2015 16:05:34
Hi MIke,
I found the perfect clip of sailors talking for your ship!!
https://www.youtube.com/watch?v=_EfW9znJYjw
#13 Posted : 02 August 2015 17:33:57
Cool idea Mike, can't wait to see how it turns out, you will have to do a video BigGrin
MikeL
#14 Posted : 02 August 2015 23:30:17
@ Gandale - Thank you - I will definitely be building a jig before I start planking. I hadn't thought that far, but can see that it is going to be important to have that.
@davetwin - Ha! I can barely post pictures, a video is way beyond my capabilities. I'm an old guy and not very computer literate.
@darbyvet - Great video - I enjoyed it a lot. Thanks for the suggestion :), but to be honest, I have a dear friend who owns Fantasonics Engineering. His name is Jim Wells and he's an ex-Disney audio engineer and is truly a wizard and genius at creating scale sound scenes. His website is www.fantasonics.com. He's done such an amazing job with my railroad, The Grand Funk Line, and my HO slot car track, the Transylvania Gran Prix, that I wouldn't want to have anyone else create sound and lighting effects for my projects.
I plan to light the gallery and the massive lantern on top. The windows are small on the gallery but I think the light will still show through the grating. Right now I'm thinking about lighting below deck where the two grates are, so some light comes through the floor there. And, I'd like to have one of the sailor's holding a lighted lantern. If anyone else knows of somewhere on the ship that should be lit, please let me know.
nightwisher
#15 Posted : 03 August 2015 00:37:19
Hi Mikel, I have seen model ships with small lanterns on the lower tops (crows nest) that would throw some light nicely onto the decks. Hope you do start a build log would love to learn about lighting a ship in the future, I haven't a clue.
Had a dream to understand
A single grain of sand
He gave birth to poetry
But one day will cease to be
#16 Posted : 03 August 2015 01:49:33
Hey Mike do you think your friend could make me some sound effects for my Jupiter train build? That would be really cool.
MikeL
#17 Posted : 03 August 2015 03:03:02
Hi Darbyvet - Anyone can contact Jim through his website at www.fantasonics.com.
This page was generated in 0.208 seconds.
