tf64 wrote:Hi Mark, Good to hear from you and thank you for your nice comments.
Mark did you know that there will be a new Model Shop opening in St George' walk Croydon in about two week time ?
Regards Trev. Hi Trev  . I did not know about the new store Trev. That is fantastic news  . Thanks for letting me know. Do you have anymore info on the store ?. I may see you in there then. Best regards. Mark
UPDATE:SPITFIRE. PACK 23. ISSUES 88/89/90.  Issue 88 contains lower wing plates 3 wooden strips and a template.  Issue 89 contains Fuselage plates plus a template.  Issue 90 contains lower wing plates and a template. More at the weekend. Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
UPDATE: SPITFIRE. 190715. NAVIGATION LIGHTS. WING PLATE ENDS. First job was to test both lights before fitting, the lights are powered by 4 AA batteries which must be the main power for the aircraft. Next I feed the lighting wire through the tube as shown in the instructions, test again when in place, you may need tweezers to help you insert the bulb.(I found I had to file out the hole it seemed to small). Same again for the left wing.   WING PLATE ENDS. After fitting the Navigation lights, I now can fit the wing end plates to both wings, I found in my build I had to adjust the fit and remove excess material that overlaps the wing tip,I adjusted mine on the curve as I need to keep that straight edge for the next plate along. The main point is to be sure that it fits in the grove on the metal rim, in my case I had to dig it out for the plate to fit in correctly mainly because it seemed to shallow. A few pictures to show.   Some times it is a good idea to make your own template to see were you are.  Top side wing plate fitted with Navigation lights. WING PLATES UNDER SIDE. I found fitting the end wing plate much the same as the top plate again I had to remove some metal from the grove to get a good fit.  This shows lower wing plate this fits next to the wing end plate, it has to be a good fit that is the reason that I removed the excess material from the curve on the wing tip. Also you will have to mark the rivets on this plate, but before I marked them I found it best to fit or make all the adjustments first i.e. make sure it fits flush and is aligned with all edges first then mark it. That's about all so far. Thanks for looking Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Awesome work, loving the navigation lights
Fabulous work Trev, love your attention to detail and the effort you are making to get the fit of parts perfect - that'll pay dividends later and make all the difference to the look of the finished model. Also love the look of the wing tip navigation light as well, super job my friend.
Well done on a top build Trev and looking forward to your next update with anticipation.
Kev
Lovely work Trev, really looking good Steve
 Hi Trev Nicely done as always Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Trev, another impressive work session from you.... looking fab m8.... Regards Alan
Hi Davetwin, Good to here from you and thank you for your thoughts, found the nav lights a bit tricky regarding the holes for fitting the lights on both sides, had to take a small file and remove a small amount of material to fit snug and a spot of glue to hold the bulb. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Kev, Loving this build and thank you for your comments, always welcome Kev. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Steve, Thanks for taking the time to look at my build much appreciate. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Andy, Thanks for looking and your thoughts. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Alan, Thanks again, hope to fit a few more under wing plates this weekend fingers crossed. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
UPDATE: SPITFIRE. 150815. PACK 91.92.93.94. This is the most recent pack to arrive, in the main it consists of metal parts, Upper wing plates, Nails, Cockpit door, Cockpit hinges, and the first Engine parts, Radiator top, Radiator sides,13mm 25mm Screws This will be an interesting build this month.   Thank you for your time. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
UPDATE:SPITFIRE. 120915 PACK 25. Issue 95.96.97.98. In this Pack we have the rest of the engine assembly I now have. Engine Cylinder Head Exhaust Manifolds Exhaust Pipes Radiator top and sides Rear engine cover Electric motor supplied by DE-AG. Looking at the Engine parts I am very pleased with the finish although as expected I will be working on them before I spray them and get them to the standard this model deserves.  Engine Cylinder block.  Exhaust Manifold.  Rear Engine Covers.  Radiator Top and side covers.  This picture shows all the parts I have to date, it also shows the Exhaust pipes.  This shows the motor purchase from De-Ag. Thank you for your time. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Joined: 27/06/2011 Posts: 437 Points: 1,321 Location: milton keynes
Looking fab Trev Regards dan Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
Hi Dan, Thanks for looking, can't wait to paint it need to check out the paint colour's first. Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Trev, great to see you have the next set of parts, will be watching as usual as you add these to your build.... good luck with it....
 Looking forward to seeing the Merlin go together Trev Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Hi Trev, I reckon that engine is going to look amazing when you put it together Steve
