Looking good Gibbo But I think your crew needs to do a better job of stowing the stores
Doing a great job Gibbo. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
davetwin wrote:Looking good Gibbo But I think your crew needs to do a better job of stowing the stores I think they're dong a great job Dave, there's too much beer and rum in the hold to fit the foodstuffs in. Cheers Paul Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
 Coming along a treat Gibbo Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Thanks for the comments and looking in, much appreciated. Paul Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
Hi Paul. Comming on nicely. I bet you notice the differnce in working on a larger scale victory. look forward to seeing more of your pictures Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
ian smith wrote:Hi Paul. Comming on nicely. I bet you notice the differnce in working on a larger scale victory. look forward to seeing more of your pictures Ian Thanks Ian, gonna have to get myself a bigger hammer and some six inch nails. Cheers Paul Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
After thinking about various ways to re-do the deck planking of The Victory so i don't have to mark them out with the pencil method, which i'm really not happy about, and taking on board all the great advice i have recieved ( thank you chaps ) i have decided to follow the official build but add to it, the 1.5mm deck support beams will be changed to 1mm, with support pillars underneath to add extra strength, then follow the build as per instructions with the 1.5mm planking, then use 1mm pre-cut and treenailed planks on top of this ( not sure what material yet, thinking about Tanganyka ) which will give me a thickness of 3.5mm, after sanding it will be or pretty close to 3mm, not changing the height of the decks and giving me the finish that i'm looking for, unless anybody can see a flaw in what is now plan "B", all comments very welcome  Gibbo attached the following image(s): Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
Should be ok. As long as you dont build up the deck beyond the intended hight as you may push out the alignment of the cannons with the gun ports Jase “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
It's all becoming clear now  Good luck with the changes! Steve
Thank you Steve & Jase Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
Hi Gibbo, can't see anything wrong with the decking plan, a lot of extra work but at least it will give you the finish you are looking for.... Look forward to seeing how it all turns out.....  ... She's looking good..... Regards Alan
Gandale wrote:Hi Gibbo, can't see anything wrong with the decking plan, a lot of extra work but at least it will give you the finish you are looking for.... Look forward to seeing how it all turns out.....  ... She's looking good..... Regards Alan Thanks Alan as you say extra work, but i think it will be worth it in the end, should be a good strong deck. Cheers Paul Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
The dummy cannon supports have been fitted and painted black, balsa in-fills have been added throughout the bow and stern sections and have been sanded to near the final stages, a little bit more refining needed and then ready to start planking.    Gibbo attached the following image(s): Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
 Great work Gibbo, She is now a vast improvement on the hulk as she was recieved.Keep the pics comming Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
arpurchase wrote: Great work Gibbo, She is now a vast improvement on the hulk as she was recieved.Keep the pics comming Cheers Andy I think i used as much if not more glue on the bow section as the previous owner used on the whole thing. Building: DelPrado HMS Victory. Building: DeAgostini Sovereign Of The Seas.
Looking good Gibbo, thanks for posting. Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Really neat work. That should plank up very nicely.
 Nicely done Gibbo looking good Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Hi Paul. comming along nicely. realy pays to balsa fill round bow and stern area. look forward to seeing more Ian. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
