Piston Jamming at Dead Bottom Options
Chasecar
#1 Posted : 19 July 2015 08:44:38
Finally put my motor together all went well I thought?
My piston is jamming at the bottom of the stroke; can look through the exhaust port and see it at the bottom so I known it's not going tight at the top of the stroke as explained in the other topic on piston jamming.
I can't recall reading anything on this problem?
Have doubled checked the assembly but I must be missing something, anyone had a similar problem?Crying
Chasecar
#2 Posted : 19 July 2015 11:26:37
Info about the piston sticking at the top is in this topic.
http://forum.model-space...spx?g=posts&t=12278
However, as your's is sticking at the bottom stroke, I would disassemble and re-assemble as it sounds like something is not properly seated.
kenjara
#3 Posted : 19 July 2015 12:38:00
You can loosen it off a bit with by heating it up with a hair dryer. I often do that when breaking in a new engine even more so when its cold.
rowdy85
#4 Posted : 21 July 2015 05:42:11
Hi Chasecar,
Something is amiss with it, so be gentle as u can. Do u notice the motor being tight at the botom only when u pull the pull-starter or is it the same when you turn the engine over by the flywheel?
AcE_w1zArD
#5 Posted : 21 July 2015 22:40:41
Id start by taking the engine out of the car (if its in)and removing the head. When its off take a look (best you can) through the exhaust port to see if you can see any warping in the cylinder liner.
Failing that take off the pull start and see if you can rotate by hand the shaft it attaches too. If not, take the shaft (and the engine back plate) off and ensure the piston is correctly fixed onto the cam. I noticed during assembly that if its not quite right it will feel stiff as there's almost 0 tolerance between the two pieces.
Failing that take out the cylinder liner and inspect it properly.
Essentially, dismantle the engine piece by piece, inspect each part for damage and verify the operation of the entire assembly at each stage by hand. Eventually you will come across a part that's either damaged or not fitted correctly, or possibly both.
I'm going on the assumption here that you definitely do mean BDC and not TDC as the posts that Tomick has linked too explain the TDC 'Jamming' thing.
Aquanin
#6 Posted : 22 July 2015 00:20:11
I bet you have the piston rod turned the wrong way. The groove should be towards the inside and not visible when you remove the pull starter plate. When I was assembling mine it did this and that was the problem. Hope that helps.
Chasecar
#7 Posted : 25 July 2015 09:54:59
Thank you all for your helpful replies.
Yep definitely sticking at BCD.
Aquanin has hit the problem spot on, I put the piston in facing the wrong way. I think in trying to be so careful during assembly I got the front and rear of the crankcase mixed upBlushing
When the piston is in the wrong way the bottom of the skirt jams on the crankshaft counter weight, only just but enough to stop it. So glad I didn't force it would have done damage to the piston for sure.
I'll update my diary build shortly with a couple of photos of what not to do.
Chasecar
AcE_w1zArD
#8 Posted : 25 July 2015 10:24:19
Glad you've found the issue Cool
Aquanin
#9 Posted : 28 July 2015 15:38:38
Missed this. Glad it helped!
