 Rank: Pro  Groups: Registered
Joined: 25/04/2015 Posts: 154 Points: 462 Location: Northern California, USA
Now the sides... DSoldano attached the following image(s): Dominick
On the Bench: DeAgostini HMS Victory, Moebius Creature From The Black Lagoon Up Next: We'll See
And finally, the stern area... DSoldano attached the following image(s): Dominick
 Rank: Semi-Pro Level 2   Groups: Registered
Joined: 30/04/2015 Posts: 75 Points: 234 Location: St. Louis USA
Brovo. Love all the pictures and info you post. I have been following from the beginning. I just got my HMS Victory and I like seeing you come together. JG 👍😎👏 In the workshop: HMS VictoryFinished builds: Providence Whaleboat
JG, Thanks m8, hopefully my posts will help others but I've gotten some great advice and helpful hints from many in here. When you start your build, start a log, the advice and help has been very well worth it for me. And best of luck to you on your build. Go slow, and don't be afraid to ask questions. Cheers Dominick
Lovely work Dominick, looking great.... Regards Alan
 Looks great now the meat is going on the bones Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Looking good Dominick Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Lovely progress Dominick  You seem to have the hang of this! Steve
Hi dominick. Planking is looking good, keep the pictures commiong. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Thanks Gents, I'm hoping to get the first set of cannon ports measured, marked, and cut over the course of this week. Dominick
Folks, Sorry, it's been slow going this last week between the holiday, work, and having a friend in town for a visit. I managed to get the frames marked but that's as far as I've gone regarding Victory construction. I did assemble a waterline marker which should help with keeping some of the cannon ports parallel to the waterline. Hopefully I'll get further this week but I haven't given up. Dominick
Alright M8s, Gun ports marked and I thought I'd post a few photos here and get some feedback before I drill and cut. So here they are, 1 per post since I am on the iPad again. One side DSoldano attached the following image(s): Dominick
And the other DSoldano attached the following image(s): Dominick
And a close up DSoldano attached the following image(s): Dominick
Looking good, gun ports look spot on, well done...... Regards Alan
Hi Dominick. Progressing nicely, look forward to seeing more of your build. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Thanks Ian and Alan, Now I can start cutting them. I also saw the DeAgostini billed for month 4 so that should arrive in about a week. My original plan was to try to keep up but I will probably fall behind, and even further when I tile the hull but no worries, I'd rather go slow and end up with a great result. One quick question though, when I drill and cut the gun ports at the bow, I assume the cannon should stick straight out to the side (90 degrees to the keel), correct? Should the gun port sides be 90 degrees to the keel as well or 90 degrees to the curvature of the planks? More to come soon. Dominick
DSoldano wrote:Thanks Ian and Alan,
More to come soon.
Hi Dominick, don't be too surprised if you fall behind when month 4 arrives, there is a lot of work to be done in that month.. Important thing is to enjoy your build, take your time to achieve the results you want as after all it's not a race you've entered but a fabulous journey. As for the bow gun ports, simple answer is the base of the port should be parallel to the water line and the gun port sides should be 90 degrees to the base of the port.... Keep up the good work, will be following.... Regards Alan
