11 Pages «<45678>»
Dave's Santisima Trinidad Build - First Wooden Ship Build Options
#101 Posted : 14 July 2015 00:18:00
arpurchase wrote:
BigGrin Nicely done , as for a flat varnish I have been using this one from Hannants for a while now. If watered down with about 25% water it sprays very well, although when brushed it can tend to foam a little so I just spray it now.
http://www.hannants.co.uk/product/XA1FF
Cheers Andy, I didnt stop to think to use an acrylic varnish that you use on plastic models on wood, I have a big bottle of Vallejo matt in the cupboard so will give thst a try on a bit of scrap BigGrin
nightwisher
#102 Posted : 14 July 2015 00:45:00
Nice job on the steps. They a much better quality than the one supplied with the sovereign.
Had a dream to understand
A single grain of sand
He gave birth to poetry
But one day will cease to be
#103 Posted : 14 July 2015 07:44:07
BigGrin Looking good Dave nice job on those steps Cool
#104 Posted : 14 July 2015 19:51:30
Hi dave at looking great.coming along very nicely.can tell your enjoying this one.look forward to more.cheers mick.BigGrin BigGrin
#105 Posted : 14 July 2015 19:58:35
Hi Dave, BigGrin
Looking very neat. Cool Cool
Keep up the good work.
#106 Posted : 14 July 2015 21:26:22
delboy271155 wrote:
Hi Dave, BigGrin
Thanks all for your comments.
I have just applied the last layer of danish oil and a couple of layers of Vallejo Matt Resin acrylic varnish to the steps.
I have also started to shape the front ribs
#107 Posted : 15 July 2015 22:54:01
I have been sailing ahead with this and making great headway LOL LOL
Hardwood strips added to edges of poop deck.
The hull was shaped for the dummy gun port strips, this was actually easier than I thought it would be, only ribs 1, 2 & 3 needed the most shaping, the rest was just a little bit of sanding required.
2 rows of dummy gun strips added and the blanking plates added too. After doing one row I decided it would be easier to add the blanking plates first and then stick the strips on.
I also flooded the fronts of the blanking plates with Super phatic glue as it runs into all the gaps and soaks into the wood, I thought this would add some extra strength.
This takes up to the start of step 25 now.
#108 Posted : 15 July 2015 23:07:05
BigGrin Coming together nicely now DaveCool
#109 Posted : 16 July 2015 01:23:23
Lovely work Dave, can see her shape starting to appear now.....Cool Cool .. Keep up the good work....Cool Cool
#110 Posted : 16 July 2015 07:41:43
BigGrin Coming along a treat Dave looking good Cool
#111 Posted : 18 July 2015 00:24:05
Thanks all for the comments
The upper row of dummy gun strips have now been added and really show off the shape of the hull. The bow end of the strips had to be soaked a bit to get the shape.
The gunwhales have been dry fitted and adjustments made for fitting then stained with Teak, I will do another coat before attaching.
During the drying period I have started to attach the gratings, after measuring to make sure they were in the centre I used the rulers as a guide for after I applied the glue.
#112 Posted : 18 July 2015 00:38:01
#113 Posted : 18 July 2015 00:41:29
BigGrin Looking great Dave, I do like the method of the pre-cut gun port strips that attach to the hull makes cutting them out so much easyer as you attach the planking[ A tip here is to cut the planks as they cover the gun ports so you dont lose them]. Also I too stained the gunwales but decided to plank them after they were fitted as it looked better to my eye but its up to you if you decide to plank.Cool
#114 Posted : 18 July 2015 01:20:04
stevie_o wrote:
Nice job Dave, I had a bit of trouble with those gun port strips but you seem to have got them on perfectlyBigGrin Really looking good.
Thanks Steve, the strips did take me a little while to do, I did find the. Quite awkward and a pain to do but am very happy with the reassurance they look perfect as they were a worry BigGrin
#115 Posted : 18 July 2015 01:23:35
Thanks Andy, I will remember the tip with the gun ports. I've had a look through your diary again and see what you mean about the planking of the gun whales, it does look much better. I might have to copy that too Cool
#116 Posted : 18 July 2015 10:26:39
She's looking great Dave, can certainly see her shape and beautiful lines appearing..... Cool Cool .. Great work,,,
#117 Posted : 18 July 2015 14:30:30
Thanks Alan, appreciate you stopping you and the comment Cool
#118 Posted : 18 July 2015 15:42:00
BigGrin Cracking job Dave looking brilliant Cool
#119 Posted : 18 July 2015 21:59:15
Thanks Martyn BigGrin
nightwisher
#120 Posted : 19 July 2015 12:04:23
Hi Dave, Looks like a mighty fine build so far, I do like the precut gunport idea, I wish the sovereign had them.Saves a load of time and hassle marking out the little blighters.
11 Pages «<45678>»
