 Rank: Pro  Groups: Registered
Joined: 21/03/2010 Posts: 270 Points: 837 Location: Nr. Dartford,
Thanks for the sound effects reference. The smoke was GREAT but needed some more bass frequencies on the fire crackers unless it was the computer speakers.  Will have to put it through the old sound studio mixer/equaliser to get the full BOOM effect.  They could have done with a poly bag of petrol in each gun!  Not advisable with the fibreglass ones though
Joined: 23/03/2010 Posts: 35 Points: 105 Location: Portsmouth
Well i was thinking of one led per port hole or one per pair on both sides (ie in the middle to light up both sides that way i only need half of the leds)
Joined: 25/03/2010 Posts: 472 Points: 1,357 Location: Hyde
Hi Having LED id each port hole sounds hood to me. It will be good idea to get them flash in sync as the each gun fires. I'll be thinking about it alot I guess. We need to put rechargable battery pack, hide all wiring, quite alot of 3mm LED's (probably amber), some resistors, on/off switch (one for lighting up the decks and one for gun firing), charging port. Quite alot to put there  but we can make it.
i was also thinking of putting a small plug in the bottom of the hull to plug an ext power supply (like charging a mobile) to light up the leds. with it at the bottom i can hide the cable when pluged in or disconnect the cable when not needed (ie to move it)
Joined: 13/10/2011 Posts: 851 Points: 2,628 Location: Leeds, Yorkshire
Hi Tarbrush -- I should explain that I am taking the audio out of my computer via an old Sony stack system with a couple of meaty speakers.
The cannon booms even had me ducking for cover!
Mike T
Had we better drill some small holes in the bulk heads, before assembly, in order to pass the wires through later?  Pity they didn't have cable ducts in the original. It's a pity we are not building a bit larger scale we could put an LED in the end of each barrel and sequence a rolling broadside. I don't think it would even be possible to drill out and fit in the thickest part of the barrel with a glass fibre bundle to take the light to the muzzle. Talking of glass fibre we could disguise a length as rope and feed the light from sequenced array of LEDs under the deck.  All we need now is smoke.  How about an electric model railway smoke kit?  I'll research this for physical and cost practicalities, unless anyone already knows.
If they didn't back then, they have now because of Health and Safety, lol
Joined: 21/03/2010 Posts: 170 Points: 549 Location: Lincolnshire
Mike Turpin wrote:Hi Tarbrush -- I should explain that I am taking the audio out of my computer via an old Sony stack system with a couple of meaty speakers.
Mike T Made me laugh at work and now I'm even more covert in visiting this site...
Joined: 20/03/2010 Posts: 219 Points: 585 Location: Faversham
I think lighting up the Victory at night would look amazing, I would definatly be interested in finding out how to do this, will be watching this thread with great interest. _____________________________________
Currently building:-
Deagostini HMS Victory
Amati Black Pearl
Mamoli HMS Victory 1:90 Scale
Caldercraft HMS Victory 1:72
Joined: 22/03/2010 Posts: 369 Points: 1,150 Location: Broadstairs
Might be a problem getting amber led's, most of the kits on sale seem to be white or blue? Not sure about individual colours? TIS
Maplins sell yellow and Orange Leds so mite get come of them
data0002 wrote:Maplins sell yellow and Orange Leds so mite get come of them Cheers for the heads up fella!! are they the small 3mm one's? _____________________________________
Amati Black Pearl
Yes here is the link to Maplin LEDs website
Cheers mate, they look perfect for the job, cheap aswell _____________________________________
Amati Black Pearl
next question is how many do we need to get also at the back of the ship where the wardroom is are they windows or are they just painted
Hi again. If you want to buy led's go to www.component-shop.co.ukThey are much cheaper than maplins. I buy all led's, batterys and chargers there.
Joined: 22/03/2010 Posts: 41 Points: 135 Location: Bristol
NICE find do you need to make a circuit for the LEDs , if so how do you do it?
Joined: 28/03/2010 Posts: 45 Points: 125 Location: Bedford
Yes going to light it up. Yellow every other gun port and white at the arse end
Joined: 23/03/2010 Posts: 202 Points: 528 Location: Bedfordshire
Tiswas wrote:Might be a problem getting amber led's, most of the kits on sale seem to be white or blue? Not sure about individual colours? TIS a little useful tip would be to use glass paint on white LED's to get the desired effect you are looking for if you use a yellow glass paint you will get the effect of various shades throughout the ship which would look better Hope this helps Allan
Joined: 17/03/2010 Posts: 128 Points: 336 Location: Windsor, Berks
rogthedodge wrote:Yes going to light it up. Yellow every other gun port and white at the arse end Is that a nautical term Follow my build to learn how to make firewood
