Joined: 27/06/2011 Posts: 437 Points: 1,321 Location: milton keynes
added some braided lines to replace the kit versions, albeit some pictures ive seen have the lines taped up in a metal foil type of tape! others the lines are visible. regards Dan dandare attached the following image(s): Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
 Looks great Dan Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Joined: 01/12/2014 Posts: 102 Points: 312 Location: Chicago, IL
Looks great. Yes Dan I saw the same thing with the brake lines wrapped too in some of the pics. Did you only cut off the kit's brake lines and just add the braided lines? or is the entire piece all scratch built bits?
I was trying to use the leftover foil to wrap on the brake lines but it doesn't stick very well. I was also trying to slide some small braided lines over the existing kit's lines but can't fit it over the piece.
arpurchase wrote: Looks great Dan thank you waiting desperately for the main body Regards Dan Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
NSXKid wrote:Looks great. Yes Dan I saw the same thing with the brake lines wrapped too in some of the pics. Did you only cut off the kit's brake lines and just add the braided lines? or is the entire piece all scratch built bits?
I was trying to use the leftover foil to wrap on the brake lines but it doesn't stick very well. I was also trying to slide some small braided lines over the existing kit's lines but can't fit it over the piece. Hi Jim i used the kit brake lines, just cut off the main pipes, i used some hose ends from RB Motion & hiroby and used a braided line that slipped into the ends for a neat look! with the banjo end of the brake line i just drilled a hole and inserted the braided line as there a little less prominent. you could try some bare metal foil if you want the taped up look http://hobby.uk.com/bare-metal-foil-matt-aluminium.htmlRegards Dan Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
Love your detailing! Walter Greetings, Walter
Thanks for the info.
On a side note, did you paint the clutch packs? I'm going to paint mine based on the pics I have. They have a bronze color to them (not sure if they are bronze 'brand new' or if they turn color over time on the real car?).
dandare wrote:arpurchase wrote: Looks great Dan thank you waiting desperately for the main body Regards Dan Me too. I bet it wont be until the last pack! Your build's coming along nicely Dan Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Nice work Dan, some superb detailing going into this - very well done.
Kev
DaDokta wrote:Love your detailing!
Walter Thank you Walter Regards Dan Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
NSXKid wrote:Thanks for the info.
On a side note, did you paint the clutch packs? I'm going to paint mine based on the pics I have. They have a bronze color to them (not sure if they are bronze 'brand new' or if they turn color over time on the real car?). Jim i left the Clutch as is, since its completely hidden once assembled to the engine Regards Dan Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
Steve279021 wrote:dandare wrote:arpurchase wrote: Looks great Dan thank you waiting desperately for the main body Regards Dan Me too. I bet it wont be until the last pack! Your build's coming along nicely Dan Thank you Steve your probably right, always leave the best bits till last Regards Dan Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
ModelMania wrote:Nice work Dan, some superb detailing going into this - very well done.
Kev Thank you Kev kind words regards Dan Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
Joined: 17/10/2014 Posts: 12 Points: 36 Location: hong kong
dandare wrote:added some braided lines to replace the kit versions, albeit some pictures ive seen have the lines taped up in a metal foil type of tape! others the lines are visible.
regards Dan if I can choose my expression, this is going to be one of the biggest WOW in my experience... you won't be able to imagine how much I admire your work and how much life you've put into this legendary machine!!!! I wish I have the skill to replicate half your work!!! very nice brake!!! what size is your braided lines?? and where can I get them?? do they do mail order??
cooper_s_1275 wrote:dandare wrote:added some braided lines to replace the kit versions, albeit some pictures ive seen have the lines taped up in a metal foil type of tape! others the lines are visible.
regards Dan if I can choose my expression, this is going to be one of the biggest WOW in my experience... you won't be able to imagine how much I admire your work and how much life you've put into this legendary machine!!!! I wish I have the skill to replicate half your work!!! very nice brake!!! what size is your braided lines?? and where can I get them?? do they do mail order?? very kind comments Cooper_s_1275  although my skill set in comparision to many of the superb modellers on the forum is very small. im not completely sure what size braided line i used think it was .6mm with the brake fittings to suit (ill check the packaging later) braided lines can be sourced from "detail master" or "hiroboy" and i got the fittings from RB Motion. Many Regards Dan Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
dandare wrote:cooper_s_1275 wrote:dandare wrote:added some braided lines to replace the kit versions, albeit some pictures ive seen have the lines taped up in a metal foil type of tape! others the lines are visible.
regards Dan if I can choose my expression, this is going to be one of the biggest WOW in my experience... you won't be able to imagine how much I admire your work and how much life you've put into this legendary machine!!!! I wish I have the skill to replicate half your work!!! very nice brake!!! what size is your braided lines?? and where can I get them?? do they do mail order?? very kind comments Cooper_s_1275  although my skill set in comparision to many of the superb modellers on the forum is very small. im not completely sure what size braided line i used think it was .6mm with the brake fittings to suit (ill check the packaging later) braided lines can be sourced from "detail master" or "hiroboy" and i got the fittings from RB Motion. Many Regards Dan Cooper_s_1275 Braided brake line was detail master 1.14mm pt no DM1304 & the "Rad hose ends" came from rb motion pt no 1529 regards Dan Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
well its been a while, and i don't have much to post. been way to busy to do any modeling lately and was waiting on some replacement parts from Degostini, which i have to say where fantastic in getting the parts to me very quickly with no hesitation whatsoever. Fantastic job Customer services thank you. well with the new parts arrived and a bit more time hopefully i will post some more progress in the next few days. well given the limited time and parts ive only managed to paint up the Turbos, heat ex-changer, header tank & Plenum chamber. regards Dan Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
managed to get the exhaust assembled and all painted up, fitted to the engine and all the assembly fitted to the mono. Added some brackets to the intercooler pipes. dandare attached the following image(s): Built - Deagostini MP4/23, deagostini Zero, Deagostini Falcon, Deagostini R2D2, Model Airways 1903 Wright Flyer, Deagostini Senna Mp4/4. Entex Mclaren M23 1/8th scale to complement the Deagostini MP4/23 & Mp4/4, deagostini Ferrari 312T4, Pocher lotus 72D, Pocher porche, Deagostini Lotus 97T on the bench, Model Airways Sopwith Camel, HK Models B-17F flying fortress, Galactica Viper, Stap droid
Looking good. The extra details are excellent. May I ask what paints you used on the exhaust pipe? Malc.
