 Rank: Semi-Pro Level 1  Groups: Registered
Joined: 22/03/2010 Posts: 66 Points: 180 Location: Horwich, Bolton, UK
Anyone know who sells those small brass pins that you use to hold the planking in place while the glue sets? A link would be helpful. Regards, Tom. Quentin Tarantino - Hallowed Be Thy Name!
Joined: 13/10/2011 Posts: 851 Points: 2,628 Location: Leeds, Yorkshire
Hi thanks for the link Mike - very useful site to know about
 Rank: Pro  Groups: Registered
Joined: 23/03/2010 Posts: 202 Points: 528 Location: Bedfordshire
I found the push pins that you use on notice boards very handy for this Allan
Joined: 20/03/2010 Posts: 219 Points: 585 Location: Faversham
Allan wrote:I found the push pins that you use on notice boards very handy for this Allan +1 _____________________________________
Currently building:-
Deagostini HMS Victory
Amati Black Pearl
Mamoli HMS Victory 1:90 Scale
Caldercraft HMS Victory 1:72
Allan wrote:I found the push pins that you use on notice boards very handy for this Allan Nice tip!
Joined: 20/03/2010 Posts: 187 Points: 526 Location: tidworth
i went to a model last week and i saw in the shop a pining tool with 100 pins for 8 pounds odd
P & S Hobbies of Walmgate, York, sell the excellent Artesania Latina brass hull pins. Highly recommended!
Thanks guys! Re the notice-board pins, I'd have thought they were a little too thick. No? Quentin Tarantino - Hallowed Be Thy Name!
Joined: 22/03/2010 Posts: 41 Points: 135 Location: Bristol
yea drawing pins are a bit thick but nice idear
Joined: 22/03/2010 Posts: 10 Points: 30 Location: Stocksfield
Re planking pins go to Miskinmodels and get 10 for £9 excellent for clamping planks to each other while the glue dries also ambush the postman and get his strong elastic bands to put around the hull keeping the planks lined up. You'll likely use nails for the first skin, I usually just tap them in until the glue sets then pull them out the mag says nip them off then sand down but this isn't necessary and it's hard work sanding brass! You will receive a plank bender in issue 5 and these are all you need to shape the planks don't buy electric benders: unnecessary. I've built Titanic Victory (Del Prado) and am nearly finished Bismarck (3 years). I crewed victory with scale figures from OnTracks morris dancers! 15 sailors Nelson and a marine officer plus 5 marines. When doing the "ratlines" hold a white card against the mast so you can see the ropes clearly. Sundance
Joined: 22/03/2010 Posts: 369 Points: 1,150 Location: Broadstairs
Sundance wrote:Re planking pins go to Miskinmodels and get 10 for £9 excellent for clamping planks to each other while the glue dries also ambush the postman and get his strong elastic bands to put around the hull keeping the planks lined up. You'll likely use nails for the first skin, I usually just tap them in until the glue sets then pull them out the mag says nip them off then sand down but this isn't necessary and it's hard work sanding brass! You will receive a plank bender in issue 5 and these are all you need to shape the planks don't buy electric benders: unnecessary. I've built Titanic Victory (Del Prado) and am nearly finished Bismarck (3 years). I crewed victory with scale figures from OnTracks morris dancers! 15 sailors Nelson and a marine officer plus 5 marines. When doing the "ratlines" hold a white card against the mast so you can see the ropes clearly. Sundance Good tips there sundance, but do you mean £9 per 100?
Joined: 21/03/2010 Posts: 270 Points: 837 Location: Nr. Dartford,
Thanks for the tip about the electric benders Sundance. You may well have saved me some expense.  I did wonder as previous boat was done without any benders all be it not very well.  I shall suck the benders provided and see.
Joined: 20/03/2010 Posts: 462 Points: 1,299 Location: Tortuga !
Hi There, Planking Pins !!! most good model supply shop will sell these, google search for best price, personally I think the model shop at the tip of the land is a bit expensive, eh, but thats just my opinion! But take a look at this pro builder and how he planks! Steve Priske,Lots to watch and learn! Russ Happy Building, Russ On the workbench: My Victory Build Diary - Victory Cross Section Build Diary - Black Pearl Build DiaryUnder the Bench: Millenium Falcon, Black Pearl x 2, Coral Victory Cross Section, De Lorean
PAULS101 wrote:yea drawing pins are a bit thick but nice idear Lol not drawing pins the map push pins with the diferent coloured plastic tops as the pin is very sharp and thin with a nice tapered point which pulls the joint tight together Allan
Joined: 06/04/2010 Posts: 58 Points: 133 Location: Newcastle uk
Joined: 26/03/2010 Posts: 600 Points: 1,959 Location: Solway West Cumbria
I have seen them on e-bay .....the prices vary ....but they do get deliverd to your door..
i think we do get the pins when we need them and u get the pin tool in that tool kit with our 3th post of issues
Joined: 20/03/2010 Posts: 226 Points: 647 Location: Merseyside
I use dressmaking pins (the ones with the coloured tops). The hole left behind is minimal and sanding usually "vanishes" the hole. Dave H
Current builds :- Hachette 1/16 Tiger Tank H.M.S Victory, Santisima Trinidad (Section), 1/8 scale Aston Martin DB5, 1/8 scale McLaren, YNWA
Hi all, I simply use push pins. I don't push the pins through the plank but adjeacent to it using the flat part on the head of the pin to hold the plank while it dries. In this way I don't end up with any holes in my planks and things seem to end up kind of neat and tidy. Hope that helps Alex
