Used Alclad2 "polished Aluminium" for the exposed aluminium of the Monocoque. very tricky masking, I think I'd do that first next time. Has anyone got any advice on the order that is best for spraying these kind of multiple colours.? Just got to do some brush work on the opening for the steering column and the nose cone latches. Added the scalpel in the shot to give an idea of the size ( or lack of it ). Malc. RM1 attached the following image(s):
 Rank: Pro  Groups: Registered
Joined: 24/09/2013 Posts: 180 Points: 550 Location: East Sussex
Loving this malc! Fantastic!!
Just about finished the painting of the bodywork. RM1 attached the following image(s):
Added a bit of cockpit detail..more to come.RM1 attached the following image(s):
Not much done this week. Somehow got distracted with other stuff. The detail on top of the tank is a little sparse so I'm going to add a bit of hosing and cable.  Malc. RM1 attached the following image(s):
 Nicely done Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
The two halves of the body are now together and the rear bulkhead + radiators in place.RM1 attached the following image(s):
I cut some shim stock to form around the air bottle and used Alclad2 for a chrome finish on the oil tank header, fuel pump and filler caps. Also added a couple of stub pipes to the tank to attach hoses. RM1 attached the following image(s):
Trial fitting...now I can plan the plumbing Malc.RM1 attached the following image(s):
Some nice scratchbuilding going on here Malc, well done, it's starting to look very cool!!
Kev
Thanks Kev. I'm going to have a bit of fun with wires and hoses at this scale ! but will see what I can do. Malc
Very nice detailing Malc, looks really good
Joined: 08/05/2015 Posts: 239 Points: 693 Location: Wisconsin
Great work!
Thats my next part to tackle now
Engine and transmission fitted Bit of a fight to get it attached but it seems secure now.RM1 attached the following image(s):
Some detail added in the cockpit.RM1 attached the following image(s):
T here is no feature on the panel behind the instruments representing the Fire extinguisher control box. I made a small box from offcuts of the sprues, sprayed it red and will add some detail to it shortly. It sits under the steering column. Malc.RM1 attached the following image(s):
Beautiful work Malc
Beautiful work Malc
