Liver of sulfer gel Options
#1 Posted : 11 July 2015 00:46:52
Found this on Amazon to patina copper tiles, Be warned this has to be mixed with 60 degree hot water to work and stinks of rotten eggs so ventilation is a must.
http://www.amazon.co.uk/...721_37038051_TE_3p_dp_1
#2 Posted : 07 August 2015 23:00:32
BigGrin Hi All
I have now used this on the hull copper tiles and also on the copper eye bolts on the Agamemnon, below are some pics of the eye bolts the effect here is a dark grey/black and was almost instant when added to the solution.
#3 Posted : 07 August 2015 23:20:15
Wow looks great Andy
greyhawk
#4 Posted : 08 August 2015 00:49:38
Wow, this looks absolutely amazing.
I assume whatever you use to mix the stuff in with water is unusable for anything else afterwards?
#5 Posted : 08 August 2015 01:08:02
BigGrin The solution will start to degrade after about 6 hours and after that will become less active but the bonus is that the solution can be used as a plant fertilizer apparently its great for tomatoes, so its green too Rofl Blink LOL Cool
This page was generated in 0.107 seconds.
