Best way to remove Acrylic paint Options
RogerThornhill
#1 Posted : 10 July 2015 15:02:03
Hello everyone,
Being new to all this and having purchased the Millennium Falcon I want to practice my painting. I have bought some cheap models and am practicing my brush painting. Now how do I remove the paint? What is the most simple and inexpensive way to remove the paint?
Thanks in advance.
#2 Posted : 10 July 2015 16:13:34
I have used undiluted all purpose cleaner and Mr muscle oven cleaner to remove acrylic paint, left part to soak over night then use a tooth brush to get into the corners
#3 Posted : 10 July 2015 17:18:53
Simple green cleaner works well Roger if you soak the parts overnight in it.If the paint is really thick the oven cleaner works better-just be careful handling it.
Metal Mech
#4 Posted : 06 August 2015 03:27:32
I soak mine in 91% Isopropyl Alcohol. Soak them for about an hour. Then I rub the loose paint off and soak for a bit longer. Then I let them dry for 24hrs and then re prime and re paint.
DeAgostini kit builds:
Shelby GT-500: 28% Complete
This page was generated in 0.113 seconds.
