Joined: 09/12/2013 Posts: 577 Points: 1,748 Location: smethwick england
So that's how you did it so fast  .If you know any gangs of riggers you can send them up the road to my sovereign. Man he took his time in the sun Had a dream to understand A single grain of sand He gave birth to poetry But one day will cease to be Greet the last light of the library...We were here!
 Hi Nightwisher Sending over drew,drew,barney mcgrew, cuthbert, dibble and grub have them for the week but there needed after that for caulking a brig. Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All The rudder has been coppered and mounted using cast blocks as the hinges and the etch straps then holding the blocks in place, something close to how it was on the full size ship I suspect. After mounting the rudder it was time to start adding the side decorations this consists mostly of pre-cast shaped brass strip with two CNC cut walnut shaped rails, next it was the pre-cut hull stairway that was added, there are still two vertical rubbing strips to add here then its onto the other side of the hull to do the same. More soon. Regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Lovely work as always Andy looking great Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Joined: 17/11/2012 Posts: 863 Points: 2,608 Location: Gohfeld (Germany)
Hi! Some fantastic work is going on, superb stuff!! Regards, Bernd
 Thanks both of you for your comments and now a couple of pic's of the rubbing strips that have been added just the quarter gallery bling to go on this side now. now for the other side. regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Very nice,starting to see now why caldercraft kits are so expensive and sort after,especially in the right hands. Man he took his time in the sun Had a dream to understand A single grain of sand He gave birth to poetry But one day will cease to be Greet the last light of the library...We were here!
 Hi Nightwisher Thanks for your comments and looking in, they certainly are great kits, so much is pre-cut like the stairs on the hull they just needed a tidy up before fitting. Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Im in awe of your build Andy. You are making modelling look so easy. Well done. On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Brilliant work as usual Andy, she is coming together nicely
Hi looking superb there andy.certainly coming along at fair pace.look forward to more.cheers mick. Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Hi Andy! Very nice and detailled work, well done as usual! Regards, Bernd
 Thanks every one for looking in and your kind words  , there's still loads to do as the outer hull detail has only just started, the beakhead and gallerys will set her off perfectly when these and some paint are added Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Andy, This is just a great build to follow I know I have said it before, but when you watch a build grow like yours you become aware of the experience of the builder. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Andy. Realy comming on now. superp work being done on her. Look forward to seeing your progress Ian. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
 Hi Trev Thanks for looking in and your comments although I have always thought there are builders on the forum with skills far higher than my own but thats what makes this such a great forum as we can all learn from others to better our own skills. Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi Ian Thanks for looking in and your comments. Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi All The brass and wood sections have now been added to the other side of the hull along with the stair and rubbing strips, next its sorting out the stern quarter gallery's and the stern gallery with more brass strip,etch and castings. More soon. Regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Looking fab Andy, always love to see the detail starting to be added to these ships and this one is no different....  .. Keep the posts coming... Regards Alan
 Hi Alan Thanks for looking in and your comments and I agree its when the detail is added that ships come to life. I have added a picture of the stern bling to give an idea of what is on there. The lemon yellow depicted is supposed to be close to how the Victory was painted around the time of Trafalgar I may mix white and yellow ochre at 1 to 1 to get a lighter yellow but we will see. Regards Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Guest (7)
