Hi Johnny. Realy nice work on your sots. look forward to seeing more. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Nice to see you back at it Jonny  Looks fantastic and look forward to more updates. Steve
She's looking great Jonny, gun ports look spot on....  .. As for your pics, looks like your file is slightly too large which is forcing people to download to view, if you can then reduce the size a little and you should be fine..... Regards Alan
 Looking good Jonny those gun ports are a pain to cut but you have done a great job . Looking forward to seeing more . Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Hi there shipmates...Thought I would make a posting to show that I have not exactly been sitting on my laurels...lol. I have spent literally weeks measuring, re-measuring and measuring again to ensure that all the old girls gun ports were in the right place before cutting them out. Cutting the gun ports out were quite a challenge to say the least!! I found that drilling just one hole and cutting out the gun port in the bamboo strakes with a craft knife almost impossible!! I tried a number of home made cutting tools to do the job but alas they were too time consuming or awkward. I settled with the idea of drilling around a dozen holes around each inner edge of the gun port using a 0.5 mm drill bit, drilling as close to each other as possible then re-drilling the same holes with a larger 1.5 mm drill bit then using a craft knife to finish off. This procedure took me a long time, what with some short planks coming loose to add to the problem!! Anyway, gun ports cut and other little problems put right, I have now begun the second planking today, and having laid the first row, I will let the glue dry a bit then use them as a base to build up on. Just one picture to post here, trying to post it was another pain in the proverbial!! Seen a lot of posts on here lately where I was unable to see the pictures that fellow modellers had posted, so I hope that this picture can be seen. Anyway...Happy building good people...Catch yer later...  jonny7england attached the following image(s): Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Looks great Jonny, your making great progress with it. Thanks for sharing with us. Chris. On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Thanks for your nice comments gents, much appreciated....Alan...Thanks for the heads up regarding the picture size...What size would you suggest I reduce them to for future postings?? Thanks again. Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
 Looking the bizz Jonny Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Made some more progress over the past few days with the application of the second planking...The second planking so far went on without any problems at all and found the sapele much more easier and pleasant to handle than other similar named materials in the past..again, only one picture, just to show my progress. I shall give the sapele a very gentle rub down with ultra fine sand paper before I tackle the other side of the hull. That's all for now shipmates...Happy building on whatever your present project...   jonny7england attached the following image(s): Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
 The second planking looks spot on Jonny lovely job Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Very nice job with the second planking Jonny, Im no expert but it does look good
 The second planking looks great, a sign you got the first planking right that it laid so well nice job Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Jonny, what a difference it makes when the second planking layer starts to go on, looking great and look forward to seeing more.... And apologies here, I missed your question relating to picture size, just for reference I resize all my pics to 600 x 480 pixels, find I've had no problems with this size.... Hope it helps... Regards Alan
Looks great Jonny.I Love it when second layer goes on. You've done a grand job there. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Hi Johnny. Looking realy nice. Look forward to the next instalment. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
 Rank: Pro  Groups: Registered
Joined: 31/03/2013 Posts: 127 Points: 395 Location: london
Hi Jonny your build is coming on a treat you must have had some good weather bud, it's nice to see the second layer of planking going on some nice work there Jonny , let's hope the sun keeps shinning for you ,  Robby
Hi there shipmates...Thank you for the very nice compliments...Much appreciated, believe me!! I have not been idle since my last posting, I have been busy fiddling about with the second planking on the lower section of the hull, which was a pain in the proverbial at times but I got there, and then I added parts of the stern gallery before heading on to issue 39 where I fitted the bowsprit assembly and keel parts. My next task is to do some tidying up of the second planking ensuring that it is nice and smooth before adding the heavy duty duck tape...er sorry...The masking tape ready for the paint job. Again, just a couple of pictures. Hope all your builds are going well...Catch yer later shipmates...  jonny7england attached the following image(s): Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Hi Jonny  . Your build is coming along great and as you know that quality can not be rushed. Keep up the great work. Best regards. Mark
 Lovely work on the planking Jonny looking good Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
